battle of the motors, diseqc, h-h 36v and actuatorsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 10-05-2009 Location: farnham
My System: sky box and mini dish |
Trying to find out which motor to have on a 85cm dish in exposed location on chimney stack. Looking for reliable, easy to set up, simple and works. Nothing too noisy. all views appreciated i just want to get it right first time. | ||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| http://www.satellites.co.uk/satellit...rised-systems/ http://www.satellites.co.uk/satellit...pictorial.html Moteck motor seems to be quite popular, exposed location might be a problem. Can you move it somewhere else? | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Not sure its such a good idea to put an 85cm on a Chimney stack to be honest. | ||
My System: sky box and mini dish | has to go there if i want to see west, dont worry about structure im an engineer and its i my genetic code to over engineer everything so by the time im finished youll be able to put jodrel bank up there. just worried about this absolute vertical pole needed for a diseqc, is there any tolerance in it | ||
| | #5 | |||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | ![]() Mukka, your main problem is going to be getting the pole plumb. Maybe use a heavy duty lashing kit and put the motor between the bracket's two U-bolts rather than above or below. I would only use an aluminium dish on a diseqc motor so there is less weight to lift going from the horizon towards the centre of the arc. Also you could use a piece of left-over steel cable from the lashing kit bridged between the dish and the mast so that if/when the motor stub becomes detached from the motor the dish can't fall and kill someone. Aim to get it perfect. If it is out east/west you are in big trouble, but if it is out north/south you can compensate using the motor elevation. | |||
| | #6 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | if your going to put a dish up there then go with a polar mount + actuator motor than a diseqc motor polar mount has much better fixing to the dish and stronger in gusty winds i wouldn't change mine for any diseqc motor | ||
| | #7 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Varying factors are: type of dish (steel or Aluminium), very exposed location, where you mount on chimney stack, what fixings ie. (lashing bracket/kit) you use, motor itself etc... | ||
| | #8 | ||
My System: sky box and mini dish | with an actuator and polar mount are there any receivers that will control it or will i need another box to control the dish, how easy are they to set up | ||
| | #9 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Limited receivers with 36v positioning. An inline Vbox positioner will be just the ticket. | ||
| | #10 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | vbox are easy to use with any receiver by using diseqc 1.2 positioning | ||
| | #11 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Wod, don't you think a 36 volt system is overkill for an 80 cm dish? 36 volt is so much more agro to set up, needs the extra control cable and doesn't have USALS so each satellite position has to be programmed in individually. | ||
| | #12 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | erm yes i must read these threads properly in future my dish is only 90cm but i went 36v as going 1.2 in future as long as the op reinforces the chimney with some support or something the dish should be fine up there. | ||
| | #13 | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #14 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #15 | ||
| You claimed 'much more agro', which may work out more expensive if this was an installer called in to do the job, but an enthiusiast doing it himself could use that additional time of programming to get used to the systems advantages and pitfalls. DiSEqC is also not perfect for finding new satellites, it is easier to count off the counts of a standard motor to get the location correct before scanning for frequencies. And in my experience a proper set up polarmount will still be on the wall and operational in ten years time, which equates to about four good DiSEqC motors (or eight cheapos) | ||
| | #16 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | ![]() My pole mounted install should be good for 20 plus - no signs of wear here, coming up to 17 now ![]() All hail to SMW engineering ![]() Llew | |||
| | #17 | |||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Dude, a USALS motor goes wherever the receiver sends it, if you have trouble locating a "new satellite" that is a problem with the box, not the motor. Maybe you can do that (almost) with a Jaegar 1224 but you can't do that with an actuator as there is not a linear relationship between the distance the ram is opened and the number of degrees moved. | |||
| | #18 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The two vertical lines on the left represent 53E and 45E - a difference of eight degrees. The two on the right (45W and 58W) are only five degrees more, but need many more pulse counts to move from one satellite to the other. Llew | |||
| | #19 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | A USALS system is quicker/easier to FULLY set up than a Diseqc1.2 or 36V system full stop! But this is irrelevant really, as the OP wants to get it right first time, which means an installation that would take a beating, such as the polar mount actuator route, as per llews example. | ||
| | #20 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Robbo, how old is the motor on your TD110? Is CH right about the life of these motors if they are turning a sensible size dish. | ||
| | #21 | |||
Might come out cheaper in the end. Just thinking of a flying dish in winter makes me shudder, even on a hot day like today in the Middle East. | |||
| | #22 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #23 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | My current motor is new, the old one, a STAB HH-90 was alomost 3 yrs old. It didn't wear out though, it was just a little too small for the TD110 above the roof line. | ||
| | #24 | |||
| Additionally a USALS motor has its basis on DiSEqC which is known to have tolerance in tracking movement. They are definitely an improvement on the earlier designs ( I was pleasantly surprised by the last one I installed last month) but there is still more that needs to be done to eliminate the backlash / gear wear, to bring them into the same league as the common polarmount designs. | |||
| There is a very fine line between "hobby" and "mental illness" | ||||
| | #25 | ||
My System: sky box and mini dish | cheers all, think i may have opened a can of worms. so am i getting this, usuals will be easier to set up, but ill be up on the roof every two years to replace the motor, and the dish may fall off actuator and polar mount harder to set up but will last forever, but needs a separate control box and a few hours searching out the satellites. But dish will stay put Seen the jaeger bit overkill i think, may be just the ticket but im trying to keep this as low key as possible so ill rule that out. Are there any receivers that will control the actuator so i dont need a vbox, Is there more tolerance in vertical pole with a polar mount and actuator. And how complicated is this setting up off the actuator | ||
| 36v, actuators, battle, diseqc, motors |
