Mounting a motorised dish on a flat roofInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #27 | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | The holes in the mounting brackets are elongated so they can slide left to right. The same is true of the holes where the mast is attached allowing adjustment in both vertical planes. | ||
| | #28 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Which satellite is your minidish pointing at in the picture above? It seems to me that if it is pointing at 28.2 East unless your motorised dish on the flank wall or on the Garage roof, you won't get 1 West or any further West. | ||
| | #29 | ||
| Regular Member Join Date: 26-01-2008 Location: Cornwall UK
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Yes you are right this is a really silly error by me but I thought I had a flat roof at the outset of this thread until I went out and observed it more closely OOPS sorry that was really dumb It is a rented accomodation I am hoping to put it on the wall now I have marked the picture with an X if you have a look can you tell me if this is an appropriate position to recieve 1W and the other satellites | ||
| | #30 | ||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | If you can get away with it, id mount it on the wall facing left, (Where the chair is). | ||
| | #31 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, the south facing wall would be ideal. On the wall with the cross, you wouldn't get much past 1W as the dish would hit the bracket, and be blocked by the wall. | ||
| | #32 | ||
| Regular Member Real name: Pete Join Date: 13-12-2008 Location: Lower Normandy, France
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema | How about going up to 18" or 24" T&K's and mounting the dish as far towards the corner of the wall as possible? That way the rim of the dish would 'peek' round the corner. Alternately, you could mount it between the top and bottom mounts of that aerial on your south wall, if no-one objected and the mast was really plumb vertical. By the way, you're going to have a difficult job painting out that red cross on the wall, seems a lot of trouble to go to just to mark up a dish site Pete | ||
| | #33 | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s |
| | #34 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Really, Thanks for telling me that -- thats pretty important. At position 1 in the photo I am attaching with this post this would be the easiest for me to install. Position 2 would be extra complicated. Would position 1 be sufficent or would the wall with the sky dish get in the way? Thanks v much!! | ||
| | #35 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Position 1 would be fine, the wall is too far round to get in the way I think. Position 2 looks to have access problems. It does of course depend on the view of the arc you have at each point as well though. | ||
| | #36 | |||
| | #37 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Position 1 it is then! So is anywhere in that area ok then? should I try to keep it to as close to the end as possible? Satelliteman can you confirm that the wall with the sky dish will not interfere! If you could mark on the photo exactly where I should put it that would be great. I would really appreciate it. Thanks | ||
| | #38 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Without a correct site survey, it's only approx. | ||
| | #39 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Judging from the angle of the minidish, the position 1 wall faces south. Judging from the position of the other wall, it would not get in the way,as you'd be below the horizon before you got that far. | ||
| | #40 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Ok I have added some more pics that I have taken from inside the upstairs bathroom to see the view from where the satellite dish will be. I am doing this as I need to be sure as my landlord is ok with four holes only so i get one chance only. Here is what the numbered point correspond to 1 the window i took the pics from 2 the bottom of the aerial from outside 2A the bottom of aerial from inside 3 proposed location for dish 4 bottom of second aerial from outside 4A bottom of second aerial from inside. So the question is will th neighbours house or anything else you experts can spot block the signal from ths position or will I be okay? Thanks | ||
| | #43 | ||
| Member Join Date: 02-04-2009 Location: Devon
My System: Technomate 5400 ci 1.1m motorised dish. Lots of PC's...I fix them. | Position 1 looks pretty good. I concur with Robbo that it looks south facing (almost perfectly so). With a good T&K mount, you should be able to see 45W no problem, and as far as I can tell from the pictures, as much east as you'd like to go? It's difficult to tell from the pictures, but I'd also suggest that you don't need to put the mount right at the top of the wall. You only need to mount it high enough to see the arc. If you could take a couple of pictures with your back to the wall below position 1, maybe we could offer some opinions. Edit to add: Looking at the pictures again, it appears you have got some trees to the east. Might be better to get it up as high as possible if you want to go beyond 45E? | ||
| | #44 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | It will only be guess work without a correct survey being carried out. Snap shots don't show the whole picture and no guarantees can be given of the range of the arc. | ||
| | #45 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | ||
| | #46 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | LOL ya I think he will be okay with 5 ha Should I stand on a step ladder with my back to the wall at the propsed dish location and take more photos? or have ye seen enough? are any more photos going to make a more accurate guesstimation? | ||
| | #47 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | From the look of it, 1W will be bang on 90 degs out parallel from the wall. Should nail a good range of the arc | ||
| | #48 | |||
My System: Technomate 5400 ci 1.1m motorised dish. Lots of PC's...I fix them. | If you are happy to install from the top of a ladder go for it, but it will mean tweaking your dish is going to be a bigger problem. One tip, if I might offer it, is make absolutely, positively, certain your mount is perfectly plumb ! ![]() Get that right, and you will save yourself a load of headaches! | |||
| | #49 | ||
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema | Yep, absolutely, positively make sure that mount is plumb. It will save you no end of headaches, not to mention trips up and down that ladder!! Don't think you have much to worry about re the arc, I have quite tall trees within 30 metres of the dish and still manage 45E. My dish is only mounted about 3 metres from the ground. Pete | ||
| | #50 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Can someone tell me what is the recommended vertical spacing between the T&K brackets if have seen somewhere in a thread it should be a minimum of 600mm! Also what length of pole should I get? And finally I was wondering if there are any issues with going too high and the eve shoots. I have ordered 18'' brackets! Thanks | ||
| dish, flat, motorised, mounting, roof |
