Mounting a motorised dish on a flat roofInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #51 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | On 12" T&Ks I've put them as close as 15" with a 90cm dish, I'd probably look at 18" to 24" for 18" with the motor just above the brackets. Also to make life easy when lining up your scaffold pole, buy one of these, only a couple of pounds, but saves lots of time. | ||
| | #52 | ||
| Regular Member Join Date: 26-01-2008 Location: Cornwall UK
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Could you please provide a larger pic or a link? Its tiny I cant work out what it is. Thanks | ||
| | #53 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | | ||
| The Following User Says Thank You to rolfw For This Useful Post: | wod (28-05-2009) |
| | #54 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Hi I am back again I am hoping to install my dish this weekend so I just need to clarify a few things. I have attached a picture with the exact proposed location. I am going to seperate the T&K brackets by 18'' on the vertical. They are extending by 18'' and the motor will be located just above the T bracket. What length of pole should I have and am I too close to the gutter from the position I have indicated on the pic. Any further suggestions recommendations welcome and appreciated. Thanks | ||
| | #55 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Should be fine, you could come down a fraction. Mount the motor on the top or either between the brackets. Either way, it's a tidy install. A 2inch mast should do it, maybe 3 foot in length, you can always cut some off if need be. | ||
| | #56 | ||
OK here's the update I have drilled two holes at the location that is shown in the last pic but I have run into trouble in a) the wall is made of three extremely hard stones including granite and the drill, the drill bit are not completely up to the job, so I may have to try and get a better drill, also I was wondering if I could come down lower on the wall as it is very uncomfortable to work that high- could anyone indicate what is the lowest I could come down on the wall and still pick up the signals- just for ease of work Thanks | ||
| | #57 | ||
| Regular Member Real name: Pete Join Date: 13-12-2008 Location: Lower Normandy, France
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema | This sounds quite similar to the composition of our walls, which are typical French farmhouse construction, i.e. 18" thick granite. My T&K's were mounted using a 10MM french bought masonry bit and my old B&D hammer drill, but you might want to think of hiring a Hilti drill, which would make the job faster and less precipitous (you might not need as much force) when you try to put pressure on up the ladder. Actually I found mounting the brackets really easy..... I got a friend to do it and he said it was one of the hardest things he had ever done!!! Pete | ||
| | #58 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Ok I think I will hire a drill - so is it a 110V drill I should hire - at least something with powerful hammer action - so I should remain at the same level on the wall then you? Also I have a timber ladder which doesn't inspire me with confidence | ||
| | #59 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | you want an sds drill if your drilling into that material as it will go through like a knife through butter use fixing like sleeve anchor bolts etc | ||
| | #60 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | A Bosch SDS 24v would do the job, you should be able to hire one. Best fixings for the job are shield anchors, either M8mm x 60mm (drill size 14mm) or M10mm x 60mm (drill size 16mm) > | ||
| | #61 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Ok thanks again I have the 8M 14mm drill size bolts and will look into hiring an sds drill hopefully it wont cost too much money- can I just ask again if it would be okay to drop the height for ease of access? All this help is much appreciated | ||
| | #62 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Fairly sure dropping the fixing point 18inches shouldn't cause to much of an issue as due South was close to 90° out from the wall. This should still give you a good range of the arc. Safety comes first ! | ||
| | #64 | ||
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema | Just to say all above good advice. Hiring a drill here in France is not quite the same, you may well get one to connect hydraulically to a French farmer friends tracteur!! Best to follow the professionals advice on here re safe working height and practices. Good luck. Pete | ||
| | #65 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | All the hiring companies are closed it being the weekend but I did have a look at a local hardware store they had a number of drills- I asked the guy if he had SDS and he showed me the hammer drills as opposed to the impact drills - they ranged in price from 60 pounds to 100 pounds but none of them said SDS on the box just hammerdrill or rotary hammer drill | ||
| | #66 | |||
| Regular Member Join Date: 10-05-2006 Location: notts uk
My System: sky + TM 1500CI 31.5W - 39E |
_http://www.hss.com/g/2361/Lightweight-Hammer-Driller-Sds.html or cordless £30.63 for the weekend _http://www.hss.com/g/2342/Cordless-Hammer-Drill.html Whats the name of your local hire centre and I'll search their site for the right drill for you. | |||
| | #67 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You might want to consider hiring a scaffold tower, makes a high level dish installation really easy, particularly useful for your first motorised installation. | ||
| | #68 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #69 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | That's a nice unit, never seen one before, wonder how much they are? | ||
| | #70 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | I think hiring a scaffolding will be too exspensive I think with the right drill I wil be okay! | ||
| | #71 | ||
My System: sky + TM 1500CI 31.5W - 39E | Even easier, get a Z10 no special licence required and a working height of 10.8m. Really easy to use and £99 for the day, used them before. _http://www.smartplatforms.co.uk/Portals/0/smart/Hire_Rates.pdf | ||
| | #72 | |||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | Maybe you could get a friend up on another ladder to give you a hand. I lowered the dish from the roof to the mount for my own install, but I had to call in a second ladder and pair of hands when installing my dads Penta. That install was similar to yours .e.g I coulndt access it from the roof. | |||
| | #73 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | A Penta 85 and motor isn't too bad, I always install them on my own without too much problem, the trick is to make sure that the top of the ladder is higher than the dish mount and it is waist high when you are working on it, then you are lowering the motor assembly into position. | ||
| | #74 | |||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Nah, what i have is easier Absolute doddle to put up an 85cm penta up with one of these _http://www.easi-dec.co.uk/products/tele-tower.php Takes 5 mins to chuck together and fits nicely in the back of a transit | |||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | ||||
| | #75 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yes like it Nano | ||
| dish, flat, motorised, mounting, roof |
