Mounting a motorised dish on a flat roof
Old 08-06-2009   #76
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Originally Posted by rolfw View Post
A Penta 85 and motor isn't too bad, I always install them on my own without too much problem, the trick is to make sure that the top of the ladder is higher than the dish mount and it is waist high when you are working on it, then you are lowering the into position.
There was my problem. I could only work from under it .
compufunk is offline   Reply With Quote
Old 08-06-2009   #77
erukus's Avatar
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8
Thanks for all the suggestions - greatly appreciated - for financial reasons i.e. me being a student it is looking like these will be out of my price range I think I will have to drop the height for ease of access hoepfully those trees of to the east wont cause me too much trouble. I thought once I got the bracket up that would be the hard part over but it makes sense that putting up the dish may be a pain in the butt too - back to the drawing board
erukus is offline   Reply With Quote
Old 08-06-2009   #78
Toute Ronde Bon Oeuf
Tivų's Avatar
Real name: Gordon
Well if you can get away with installing the Dish at reduced height, it makes post-Installation twiddling and Maintenance soooooo much easier
As regards the trees (says he, reading back through the Thread!), I have some massive trees in the field behind me that cause a heck of a lot less problems than you'd imagine from simple observation.
Tivų is offline   Reply With Quote
Old 08-06-2009   #79
rolfw's Avatar
Real name: Rolf
Have made a sticky thread on access equipment. http://www.satellites.co.uk/satellit...tallation.html
Rolf
Old 08-06-2009   #80
erukus's Avatar
Ok sorry to be annoying now but I just need clarification will this new position I have highlighted in green be ok I Have to drop the level for safety and due to the fact that I cant afford scaffolding or similar
Mounting a motorised dish on a flat roof-jpg
Old 08-06-2009   #81
satelliteman's Avatar
Real name: Paul
Well, looks fine from what I can see
satelliteman.
An Installers Choice
Follow us on
Old 08-06-2009   #82
rolfw's Avatar
Real name: Rolf
Yep, I agree.
Rolf
Old 10-06-2009   #83
erukus's Avatar
Ok everything is going to plan I have hired an SDS drill what a machine. Anyhow my question is when I mount the dish/motor on the vertical pole do I tighten it when the arm of the dish is facing due south?
Old 10-06-2009   #84
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
Yes. The motor body should be pointed due south from the mast, and when the motor is at zero the dish should point due south also.
Huevos is online now   Reply With Quote
Old 10-06-2009   #85
rolfw's Avatar
Real name: Rolf
Your best bet is to set your coordinates in your receiver, then send the dish using USALS to 5W (your nearest due South satellite), then use the alignment meter to align on 5W as per the sticky threads.
Rolf
dish, flat, motorised, mounting, roof
[IMG] code is Off
