Mounting a motorised dish on a flat roof | |
| Regular Member Join Date: 26-01-2008 Location: Cornwall UK
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 |
Hi, I want to put an 85cm motorised dish on a flat roof. I just spoke to one of the forum sponors about purchasing the dish and he said I would need 3 roadside kirbs to hold it down on the flat roof. Does anyone know of a better way or where i could get this concrete kirbs? ANy further help appreciated! Thanks | ||
My System: Zone1 Dish, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR, TM-5200D, Gibertini 104cm, Invacom SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM-1s | Hi erukus, yes consider a more practical route and install a 3' x 2" non penetrating roof mount as suggested | ||
Ok so I would need some rubber matting and the roof mount as shown on the attached thumbnail. Do you know Where I could purchase one of these and also how would this be secured? Would I need to put concrete blocks on it. I am at rented accomodation so i am looking for the easiest method. I have been granted permission to put up a wall mount so maybe this is an easier option? What do you think? | ||
| | #5 | ||
My System: Zone1 Dish, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR, TM-5200D, Gibertini 104cm, Invacom SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM-1s | Slabs will secure the mount and they come in different sizes. Mounting a motorised dish on a wall mount would be a cheaper option. Consider a T&K fixing but avoid the 'L' type bracket. There is just too much movement with these ![]() T&K shown below > | ||
| Last edited by satelliteman; 18-05-2009 at 06:17 PM. Reason: Attachement added for reference | |||
| The Following User Says Thank You to satelliteman For This Useful Post: | erukus (18-05-2009) |
| | #6 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | I am thinking of using a Fracarro Penta 85cm dish could you recommend a motor for this dish? | ||
| | #7 | ||
My System: Zone1 Dish, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR, TM-5200D, Gibertini 104cm, Invacom SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM-1s | I certainly could and as Del boy would say, "they are one of my most bestest dishes !!" Works with any DiSEqC H-H motor. Fitted many using the Moteck2100 and Technomate 2200. | ||
| | #8 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | just some paving slabs from a diy place will hold it down, it would be a good option if you can do this mount on a roof | ||
| The Following User Says Thank You to wod For This Useful Post: | kenny1234 (26-05-2009) |
| | #9 | ||
| Regular Member Join Date: 04-09-2006 Location: Kent, UK
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | In a lower league to that ground mount mentioned in post 3 is e-bay item 310082854450. The latter is thrown in the mix just because it is possibly easier to get and much cheaper. | ||
| | #10 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | As a wall mount is permitted, that would be the cheapest, easiest and best option. | ||
| | #11 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Hey Bigtee that looks like a good option what would I need to secure it surely one patio slab wouldn't be sufficient? would it? Does anyone have experience with this product and would it need to be exactly level for a motorised dish? | ||
| | #12 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | With any single axis motorised setup, the general idea is that the pole is vertical yes. It makes the setting up process very much easier. Depending on the dish size, that small mount might be Ok, with one of the large council pavement type slabs, but I think that with one of the standard domestic size slabs the dish could get blown over. If it was for my own setup, I'd try it on a large slab to save spending out out on the proper mount, but for a professional job, stick it on the wall, or use the proper mount. | ||
| | #13 | ||
| Regular Member Join Date: 04-07-2008 Location: Exmouth, Devon
My System: DreamBox 600s, Darkbox 2008, Liberty FTA reciever, Humax Foxsat HD, Thomson Sky+, 3 fixed dishes, 60cm for 13E + 19E, 80 cm motorised,Zone 1 sky+, BtVision and My 37" baby. | just to add something if you do use the k & t dont put the bolts in the morter as it would apper that the picture shows ( top 2 bolts on the K) | ||
| | #14 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Hey I am going to purchase my dish and motor from the site advertisers but does anyone know where I can purchase one of these U brackets to fix the dish with? Thanks | ||
| | #15 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | better to mount the dish on t&k brackets with a short piece of scaffold pole. you can get them from tv aerial shop etc | ||
| | #16 | ||
My System: Zone1 Dish, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR, TM-5200D, Gibertini 104cm, Invacom SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM-1s | You may get movement with that bracket and getting it plumb may be a problem if the wall is out. As said, T&K 12" or 18" should be ok. | ||
| | #17 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | OK I have spoken to the guy at High Definition the supporting advertisers and he has said to me that from what I am describing i.e. my location or proposed position for the dish that an L type bracket wall mount would be better. So I have attached some photo's of the house wall and proposed spot of the dish to get clarification of what type of bracket I should use Thanks | ||
| | #18 | ||
| Regular Member Real name: Pete Join Date: 13-12-2008 Location: Lower Normandy, France
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema | Although I wouldn't assume that I knew better than a pro, I can only give you advice from my own experience. I bought an 'L' bracket which was okay until I upgraded to an 88cm dish. This threw out the vertical alignment of the bracket and I had to adjust the motor elevation to compensate. It was very fiddly and unsatisfactory. I've since moved the setup to different site and upgraded to T&K's. This proved to very stable and once aligned no problem. Personally, I would recommend these above an 'L' bracket. you can find pictures of my old and new setup under the relevant thread on this forum. Pete | ||
| | #19 | ||
| Regular Member Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: 1) Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... 2) Fibo 90, Mot-Sat3, Manhattan Plaza XT-M | Just agreeing with SonnetPete. The difference between an "L" bracket and using T & K's is that T & K's are adjustable while an "L" bracket is not. | ||
| | #20 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Ok so the pole is adjustable with the T&K brackets is that what you are saying? Isnt it only adjustable on one axis though i.e. the Y axis in geomtrical terms? | ||
| | #21 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The holes in the brackets when fixed to the wall will have scope for adjustment, but you will of course have made sure that they are plumb with each other (using a plumb line), so very little adjustment in the (three dimensional) x-axis will be necessary. Llew | ||
| | #23 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | No, two planes - one for adjusting the pole on the brackets, and one for adjusting the brackets on the wall. | ||
| | #24 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Obviously it will have scope for adustment in two planes before it is attached to the wall. When it is securely attached to the wall will it have scope for adjustment in one or two planes? | ||
| | #25 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The T&Ks are the better solution. The pole can be adjusted left and right, and forward and backwards. It is also much stronger and more stable than the L-shaped bracket. It can be made spot-on vertical every time, without any difficulty. The L-shaped bracket is only really any good for a fixed dish, unless you like making life difficult for yourself. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | erukus (26-05-2009) |
| dish, flat, motorised, mounting, roof |
