Would a DiSEqC motor have any effect on the signal quality?
Hello,
I'll give Astra 2D a try from Sweden soon, but I'm also thinking about getting a motor so I can also use the same dish for the scandinavian Thor sats at 0.8°W. Do you think a motor (correctly setup) would in any way worsen my chanses of getting Astra 2D?
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs
Any interruption to the signal path along the cable by insertion of a device will lose you quality depending on the rated signal loss for that device. So in answer to your question I would have to say yes
Formerly toppervte33h whose six pack has turned into a keg
Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button Thank you. Freddie Flintoff is back
Hello,
OK thanks. The cable isn't very long, about 10 meters in total I think.
The LNB I'll use will be suited for bad reception since the Astra 2D reception is very weak in Sweden. However, the reception from Thor is very strong. Could that be a problem for the LNB?
Also, the dish is a 110 cm with 42,0 gain at 12,75 Ghz (dBi), does that figure (dbi) has anything to do with your figure of 2 dB signal loss?
