Finding south using the sun?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 22-05-2009 Location: Mijas, Malaga, SPAIN
My System: Sat dish 120cm approx Box Pace BskyB 2200 Lat. 36.582 degrees Long. -4.638 degrees |
I've just discovered my compass measurements are all out since I was just leaving it on the floor of the roof terrace and its readings must be distorted by the metal/iron in the concrete becuase when I hold it in my hand I get very different readings and as I lower towards the ground the readings all change? My question is is I use the sun bearing in mind I am in Southern Spain do I take the position at 12 GMT to be south? 12GMT = 2:00pm local time correct? approx mid-way between east and south is where my Sat for Astra 2D should be pointing as setup data for my location says True 132.7/Magn 134.7 As always any helpful comment always appreciated! | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | No it's not correct. The sun crosses the zero meridian at 12 GMT. Malaga is nowhere near the zero meridian. Also because the earth is not in a circular orbit around the sun the precise time the meridian is crossed deviates up to half an hour over the year. Forget this idea of using the sun. People install satellite systems in Britain every day and the sun never shines there. A fixed dish is pretty simple to set up. Just set the correct elevation and LNB skew for your location and then just swing the dish around the pole to nail the correct satellite. If you want to get a rough idea where to point use _dishpointer.com | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | | ||
| finding, south, sun |
