Multi LNB on a Big Dish queryInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 15-04-2006 Location: Gran Canaria
My System: 3mtr Offset dish, 1.2m Dish Astra 1, 1m Dish Nilesat, 1m Dish Hotbird, Humax Freesat HDR, Cheap FTA Sat box, Quality AV. |
Hi, Could someone tell me if the distance between centre points of multiple LNBs varies with dish size or if the distance remains constant irrespective of dish size? I.e to watch 2 satelites on a 1meter dish (offset) would the linear distance betwen the 2 lnbs be the same as 2 lnbs geting the two satellites on a 3 meter dish (offset )(my trig is not that good). Finally the important question, taking into account the size of a lnb head, what would be the closest degree satellite I could get to the prime satellite on a 3 meter dish. I.e.if lnbs touching what degree of separation would that equate to? Thanks in dvance. | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | It changes - the lnb distance apart for any two particular satellite slots will decrease as the dish size increases. | ||
| | #3 | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT |
A very rough calculation can be used to work out the spacings of the LNBs. 1. measure the distance from the dish centre to the focal LNB- Call this F 2. The anglular separation of the satellite at the focus and the offset one. Call this A. 3. Let the distance between the LNBs be P Then, Tan(A)= P/F thus P= F x Tan(A) Or in words, take the Tan of the angular separation and times by the distance between the LNB and the dish. It will give a ballpark figure, a bit of jiggling around to get the best signal will be needed. Generally the bigger the dish, the longer the focal length and thus the further apart the LNBs will be. BUT, this is not always the case. If the larger dish is a prime focus for example, the focal length, most likely will be fairly short compared to the diameter. So it is possible to have the same separation on a 1m offset dish as a 2m prime focus (for example). To work out the closest sats you can receive with your dish, first measure how close you can get the LNBs (P1) (measure between centres), and the distance away from the dish (F). The closest sat you can receive is the roughly:- InverseTan (P1/F) separation. | |||
| big, dish, lnb, multi, query |
