Please Help, my HH120 motor is knackeredInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 01-01-2000 Location: pj::
hi guys i need some help please MY HH 120 motor is knackered after 4-5 years so time for a new one iam looking for a motor to run a channel master 1.2 dish 15kg is the HH120 the only motor that can hold this dish ??? as it can hold 17kg , so what i wont to know is what is the best mortor to buy for this dish is the stab worth the exter money over all the other motor??? thanks for your time guys | ||
| pc:: | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | A polar mount and linear actuator would be the best option. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Also the supermount 1224 will fit that dish with the offset adapter plate. | ||
| | #4 | |||
| Member Join Date: 27-04-2009 Location: Malta
My System: Dreambox 8000 HD Dreambox 800 HD Clark Tech 5000 HD EchoLink 700FTA |
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | for that dish, it is advisable to use the 1224 motor as it has plenty of power to move it being 36volt | ||
| | #7 | ||
| just got my new motor today and would like some help please what satellite is my south facing with these Latitude: 53.3043° Longitude: -6.2022°Dish Elevation:28.9° Azimuth: 173.3° LNB skew: -4.0° thanks for you time guys | ||
| pc:: | |||
| | #8 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The satellite closest to your longitude that is easy to pick up, i.e 5W in your case. Which motor did you get? | ||
| | #10 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | No, 0 on your motor would be 6.2022W, as that is your longitude. Which motor did you get? | ||
| | #12 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | That's easy then, if your receiver supports USALS. Just put in your details and send the dish to 5W, and align for it as per the sticky guides. If no USALS, you will need to send the motor manually to about 1.2 degrees east before doing the alignment. | ||
| | #13 | ||
| Member Join Date: 02-07-2009 Location: Meath, Ireland
My System: Up and running -> FR Penta 85 dish, TM-02 twin LNB, TM-2300 motor, TM-5200D receiver | Sorry to butt in bilbo but I am same Lat as you and used USALS and 5W for lining up which seems to have done the trick. I think it was Robbo who recommended USALS but I have been meaning to ask should I then change over to Disceq 1.2 once the dish is setup or does it make a difference? | ||
| | #14 | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | If you are happy with the results, just stick with USALS. Some people claim the USALS Algorithm doesn't quite do it for them, but I suspect that merely hides small inaccuracies in their physical installation! | ||
| | #15 | ||
| i will be using it with a dreambox 7000s that i picked up last mth i dont think the dreambox has USALS ??? just has goto x or would i do better to change the image using Gemini 460 now thanks for your time guys | ||
| pc:: | |||
| | #16 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The Dreambox images usually have Goto X instead, which is a different name for the same thing. Really, use what you find works easiest. I suspect that it will be Diseqc 1.2 in this case. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | billbo (19-07-2009) |
| | #19 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | For AB3 @ 5° West, try 11.591v, 20000, 2/3. Nice and easy to identify, France 2, 3 & 5. | ||
| | #20 | ||
| thanks very much got it going i hope 1.2 dish picking up signal of 87% then i go to 28* getting signal of 81% go to 30*w and picking up a signal of 78% this sound right ??? thanks guys | ||
| pc:: | |||
| | #21 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Well done, sounds ok. | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | billbo (01-10-2009) |
| | #22 | ||
My System: Up and running -> FR Penta 85 dish, TM-02 twin LNB, TM-2300 motor, TM-5200D receiver | I get 100% signal levels on 28E with smaller dish. Probably with some fine tuning you could do the same. | ||
| hh120, knackered, motor |
