I'm not getting 11766H on Nilesat in Egypt
Old 24-06-2009   #1
My System: astra 9500
Unhappy I'm not getting 11766H on Nilesat in Egypt
I have a problem I changed the fec to 5/6 and I'm not geting any signal.. or to be more Specific the image is forzen.. Is there any other fec I can use to get FOX Movies on nile sat since I don't have Badr... I have the same problem with all the channels that has the fec 11766..
I 'm not really good at setting up the reciver so if you give me instruction can you give it to me in details.. Thanks
how is 567 is offline   Reply With Quote
Old 24-06-2009   #2
Robbo's Avatar
Real name: Mark
I ve started a new thread for you as you are in Egypt, which couldn't be any closer to the centre of the Nilesat footprint if it tried, so not Fringe reception.
No, Fox movies is only on that transponder with that fec
_http://www.lyngsat.com/nile.html
I suggest that you delete the transponder and rescan, if you still don't get the channel, then check the usual, cable, dish, LNB etc.
Old 24-06-2009   #3
My System: 210cm dish Astrovox 290
depending on your receiver-pls rescan or manually input the frequncies.
Kiprono is offline   Reply With Quote
Old 24-06-2009   #4
how to add badr?
ok I have anther question.. how do I add Badr to my satellite collection since I can't watch FOX Movies on Nilesat... I have an ASTRA 9500 receiver & if it's not too much troubel I need the instructions in details since it's going to be my 1st time doing that
Old 24-06-2009   #5
Amo Amas Amant Admin
Topper's Avatar
Well
You may be experiencing EM radiation from other equipment which is blocking that frequency, could it be you have a WIFI router near or a DECT phone. As it is quite near the Lo band problem area:-
11630 to 11650 MHz (9750 MHz LO) IF is 1880 to 1900 MHz
You would have to move your dish to achieve Badr, have you got a motorised system?
If not I refer you to to the dish setup section of the forum as the point of a written forum is so that others can read it.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 26-06-2009   #6
Please remind me the type of receiver (decoder)you are using.this will enable me to guide you how to input the frequencies
Old 28-06-2009   #7
Astra 9500
Old 1 Week Ago   #8
User without a clue
Hi everybody,
I've been having the same problem for ages, can't get Foxmovies, not even a signal for the frequency. I'm in Egypt too. It used to be on during the day then disappeared at night, now absolutely nothing.
The weird thing is we have an astra receiver downstairs and it picks up Foxmovies fine, the one upstairs (using a dvb card) doesn't. Could the problem be with the upstairs dish's LNB? It was one of those dual ones, you know, the sort you can attach two cables/receivers to. The installers I've asked say it can't be an LNB problem It's rather annoying. Any help much appreciated.
afrowoman is offline   Reply With Quote
Old 1 Week Ago   #9
Robbo's Avatar
Real name: Mark
Why not move the receiver that works to the room that doesn't, in order to eliminate the cable and lnb as a cause.
Old 1 Week Ago   #10
User without a clue
That's what the sparky suggested I do but didn't think it would be worth the trouble, will give it a try! Thanks Robbo
egypt, nilesat
[IMG] code is Off
