8 way Diseqc switch How do they work?
Old 03-07-2009   #1
Real name: Colin
My System: 90cm Fortec Star Dish 1.2mtr Channelmaster Dish Manhattan Plaza 3300 Receiver
Hello there i hope someone can answer me a question regarding DiSeqC switches.
I understand how a 4 way works as ive had one before i used to have a 4way in the following way:
lnb 1 = 13e Hotbird = DiSEqC A on receiver
lnb 2 = 19.2e Astra 1 = DiSEqC B on receiver
lnb 3 = 0.8w Thor = DiSEqC C on receiver
lnb 4 = 7e Eutelsat = DiSEqC D on receiver
My question is if this is the way a 4 way works how does an 8 way work.
Do i need a switch or do you run two satelklite cables into the house. Sorry if this question has been asked before.
Colin
wa1es_4_ever is offline   Reply With Quote
Old 03-07-2009   #2
Robbo's Avatar
Real name: Mark
Not used one, but they use Diseqc1.1 instead of Diseqc 1.0, as Diseqc 1.0 can only work with a max of 4 inputs. You can also feed two 4-way Diseqc 1.0 switches into a 2-way diseqc 1.1 I believe.
Some switches also use Diseqc 1.2 and and controlled like a motor.
diseqc, switch, work
[IMG] code is Off
