Polarization and satellites positionsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Regular Member Join Date: 06-04-2004 Location: Riyadh - Saudi Arabia
| Hi, ppl could anybody can explain to me technically , The relation between polarization and satellites positions ( Regarding to the Rule that the polarization depends on the difference between the geographical longitude position of the receiving site and the orbital position of the satellite . ) . Any thoughts you would have be greatly appriciated . Best Regards A.M.AL-Madhi | ||
| AL-MADHI | |||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | It depends on the latitude too. For example, if you are at the equator there is no skew change whatsoever. | ||
| | #3 | |||
| Member Join Date: 27-04-2009 Location: Malta
My System: Dreambox 8000 HD Dreambox 800 HD Clark Tech 5000 HD EchoLink 700FTA |
• Elevation - Angle between the Earth and the satellite above the horizon. This is also referred to as the up or down movement of the satellite Dish. • Azimuth - Compass direction the antenna is pointed towards, relative to a magnetic north. This is also referred to as the left or right movement of the satellite Dish. • Polarization - Correction between where the antenna is relative to the curvature of the Earth, in other words your Location, and the satellites signal beam. The satellite signal is either Horizontal or Vertical polarized, but due to the longitude of the antenna location, the Dish feed horn must be rotated to correctly match the beam's polarization. Hope this helps to answer your query. | |||
| polarization, positions, satellites |
