How long will last motor, designed for 1.2m dish, with 1.5m dish?
Old 14-07-2009   #1
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
Hello.
I have SG-2080 motor, according to manual, it can take dishes up to 1.2m. I want to equip it with 1.5m fortec star dish. Motor will be moved very rarely, say, 2-3 times per week. Will it last for year at least?
BombedOne is offline   Reply With Quote
Old 14-07-2009   #2
Toute Ronde Bon Oeuf
Tivų's Avatar
Real name: Gordon
That depends: How sheltered is the site?
I had a 1.1m Dish on a 1.2m specified H-H Motor and had to relocate it pronto from a house wall to a ground mount in a sheltered spot because I was not at all happy with it in even moderate winds. Wind loading affects the motor even when not in use, of course.
Also, the specified size limitation on the motor needs to be tempered with consideration of the weight of the particular Dish.
Tivų is offline   Reply With Quote
Old 14-07-2009   #3
Robbo's Avatar
Real name: Mark
Yes,depends on the weight.
I had a Triax TD110 on a small Stab for 90cm dishes, it worked well for almost 2 years.
But then I put a 90cm Fibo on it, and it sh&gged it.
(fibo very heavy)
Don't know what the FS 1.5m is like, but their 90cm is very flimsy and light.
Old 14-07-2009   #4
rolfw's Avatar
Real name: Rolf
The 1.5m fortecstar is quite heavy, but more important is the surface area and the way the dish will swing when moving, it is just as likely to strip or jam the gearing.
Rolf
Old 14-07-2009   #5
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
1.5m dish has got 56% more surface area than a 1.2m. Also a 1.5m dish need a 3" fixing or the wind will just turn it.
Huevos is offline   Reply With Quote
Old 14-07-2009   #6
BombedOne's Avatar
I don't know exact weight, but I can lift that dish with one hand without any problems, maybe around 10-15 kg?
This dish will be used for DXing, stable reception is not required, so wind instability can be ommited.
Old 14-07-2009   #7
I've got a donkey. His old owner says he can carry 150 kilos of firewood but I want him to carry 250 kilos. How long do you think it will be before he dies of exhaustion? By the way he doesn't need to be reliable because I'm only going to make him do it 2 or 3 times a week.
Old 14-07-2009   #8
BombedOne's Avatar
mucho gracias, mi seņor
Old 14-07-2009   #9
Robbo's Avatar
Real name: Mark
Obviously, if the motor is 'dispensable' like my stab was, you could try it just for the hell of it. It was quite interesting hearing my motor tearing itself to death, the noise woke all the neighbours up.
Wouldn't put a donkey through that though.
Old 14-07-2009   #10
satelliteman's Avatar
Real name: Paul
Well put
satelliteman.
An Installers Choice
Follow us on
Old 14-07-2009   #11
Amo Amas Amant Admin
Topper's Avatar
Well
it has nothing to do with wind stability the problem that everyone is trying to alert you to is the reverse loading on the gears caused by the large surface area of the dish , this is multiplied in the same way as servo on a braking system works. A large area receiving a large force will equate to a small area as in the gearing receiving a massive force, in the same way as a stiletto heel on a dainty woman will make puncture marks in a floor covering.
It would be foolish to say the least to attempt this.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 14-07-2009   #12
BombedOne's Avatar
Yes, this motor is "disposable", I'm not aware what going to happen to it, just I'd like to estimate how long it will last with such load, day, hour, 5 minutes, 4 months or century?
Old 14-07-2009   #13
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
Wouldn't put a donkey through that though.http://www.satellites.co.uk/satellit...ilies/wink.gif
Eo eo eoalways says that
CROSSBONES is offline   Reply With Quote
Old 14-07-2009   #14
Real name: Paul
Have a back up motor or two standing by. Not something I'd attempt
satelliteman.
Follow us on
Old 14-07-2009   #15
Robbo's Avatar
Real name: Mark
No pain no gain, in for a penny in for a pound, and all that, but only in my own back yard.
Old 14-07-2009   #16
My System: echostar ad 3006 ip with 5 foot dish 48east to 30 west. computer is a packard bell
I loved the donkey story...I put a bigger dish on a small moter it lasted 1 year the right moter has been going strong now for 5 years now.
GTA8910 is offline   Reply With Quote
Old 14-07-2009   #17
doktorofsat's Avatar
My System: C BANDIT
Bombed One, 1.5m fortec star dish,is a offset dish??
Or am I wrong?
If it is a offset go for an offset polar mount .I think I still have one in the cellar .I used it 5 years with a 100cm very good noname dish and got 42east-30west with a 12" actuator.
Pictures of polar mount for offset tomorrow
doktorofsat is offline   Reply With Quote
Old 14-07-2009   #18
Nolia's Avatar
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E
Wink
Tengo gusto de lo que escribiste a Sr. Huevos
I like what you wrote Senor Huevos
Nolia is offline   Reply With Quote
Old 14-07-2009   #19
BombedOne's Avatar
Hello Doctor
The dish is offset one.
There's one HUGE difference between me and you. You already have polar mount, while me - not. And I'm not planning to invest money in it, just trying to re-use existing stock of "expensive junk" (as my wife calls them) as much as I can.
The Following User Says Thank You to BombedOne For This Useful Post:
doktorofsat (15-07-2009)
Old 15-07-2009   #20
Tivų's Avatar
Real name: Gordon
.......... just trying to re-use existing stock of "expensive junk" (as my wife calls them) as much as I can.
Ah, yes.
Much common ground there .............
Old 15-07-2009   #21
My System: C BANDIT
Hello Doctor
Hello Bombed One
As I promosed here is the picture with da polar mount for offset dish:
_http://img505.imageshack.us/img505/9347/polarm.jpg
"expensive junk" (as my wife calls them) ..
does she have her own setup ?(dish , receiver..) maybe changed her mind
Old 20-07-2009   #22
BombedOne's Avatar
lol haha
Generally when she starts arguing, I'm reminding her, how much we paid for her car, and how big dish I could buy with that money
12m, 15m, designed, dish, long, motor
[IMG] code is Off
