required dish size in Athens
Old 17-07-2009   #1
My System: Astra/Hotbird
I'm enquiring on behalf of my brother who has moved to Athens/Greece. What dish size would be required for a multiple lnb system to receive:
a: 13e + 19.2e?
b: 13e + 19.2e + 28.2e?
Many thanks for your help
Martin
marty80 is offline   Reply With Quote
Old 17-07-2009   #2
satelliteman's Avatar
Real name: Paul
Reported that 28e 2D beam alone will require a 3m+ for reception.
satelliteman.
An Installers Choice
Follow us on
Old 17-07-2009   #3
ok, so no chance for 28.2e. How about 13e + 19.2e?
Old 17-07-2009   #4
zorbua's Avatar
My System: Dreambox 8000 HD Dreambox 800 HD Clark Tech 5000 HD EchoLink 700FTA
Should be able to receive all of 13e & most of 19.2e. I would suggest that you go to 26e instead of 28.2. Some good fta channels on 26e.
Just for your info. I reside in malta....(not much difference in Lat with Athens and I receive all these Sats with a very good signal strenght plus a sizable amount of 28.2e.
zorbua is online now   Reply With Quote
Old 17-07-2009   #5
He would want 28.2e to get the British channels (BBC, ITV, CH4). But not if you need a 3m dish. I guess 1.5m would be the maximum dish size.
But my original question was what would be the minimum dish size to get 13e and 19.2e on one dish in Athens? Would something like 80cm be enough or would it have to be something bigger?
Cheers, Martin
Old 17-07-2009   #6
zorbua's Avatar
Cheers, Martin
Sri M8, I intended to tell you...somehow it slipped my mind.... A 1 Meter Dish would be enough, probably even an 80cm one should do it for the13e and 19.2E.
I have a 1.2 meter Dish (beside a 1Meter one ) and I can receive.... the BBC Interactive channels quite strongly..... Itv anglia W and ITV 1 Central SW,... and CH 4 on Freq 12480 V with a 48% (SNR), also Ch 4 HD on 11798 H with a signal level of 83%. Even the ITV HD comes in although always with the caption of ''This service is currently unavaiable'' and rather weak, but no pixalation whatsover. Anway all in all I can say that I receive more than 200 channels from the Astra 28.2 with this 1.2 Dish, and all of the Hotbird and Astra 19.2.
Old 18-07-2009   #7
Amo Amas Amant Admin
Topper's Avatar
Mmm
Zorbua
It is foolish to begin making comparisons between what you can receive in Malta and what the o/p wants to receive in Athens/Greece. With fringe reception a 10Km difference in longitude or latitude can make a two fold difference in dish diameter. Athens is 9 degrees further east how can you possibly compare the two.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 18-07-2009   #8
zorbua's Avatar
Originally Posted by Topper View Post
Zorbua
Lets start at this point, I have seen the Lyngsat satellite footprint for the 13e and 19e as regards Athens and and if you cared yourself to have consulted it you would have come to the same conclusion as I did
mister so I don't think thats foolish. Secondly I advised him to go for the 26e instead of 28.2 for the simple fact that again according to Lynsat Charts he won't be able to receive the 28.2e as well as the 13e and 19.2e although I stand to what I informed him, that he will be able to receive the 28.2e but in restricted form. The proof of the pudding will be if he puts up a 1 meter Dish for the 13e and 19.2e and a 1.2 for Astra 28.2 and then he can tell us who is foolish or not. Oh btw thank you for gracefully granting me an infraction for helping a fellow member with his problem you could have told me that bin files etc etc are not allowed.
Old 18-07-2009   #9
Topper's Avatar
Mmm
When you signed up to the forum you agreed to abide by the rules, perhaps you forgot to read them!
As regards the content of this thread, we appear to be getting at cross purposes here zorbua. The o/p who resides in England is referring to his brother having moved to Athens who appears to be expecting to get from 28.2 East in Athens, exactly what he can got in the UK and in order to do that he will require in the region of a 3.0mtr Dish. Perhaps my wording of foolish was incorrect and therefore for that I apologise, I should have use the word misleading to be more accurate
Nowhere in my posts have I ever mentioned not being able to get 13 East or 19 East since having lived in the Middle East I am well aware of what can and cannot be received in the Eastern Mediterranean and do not need to 'care to check lyngsat' for what I already know.
Show Your Support
Thank you.
Old 18-07-2009   #10
zorbua's Avatar
Actually yes, I did not read them, most probably thought they will be as other Forums, never thought that you cannot post 'bin files' keys' etc. etc. my fault, and I too apologise on that aspect. As regards the o/p, I fully understood that to be able to receive whatever his brother received in the UK entailed a 3 meter Dish, no question about that, in fact thats why I adviced him to go for the 26e, instead, if he wanted too, but if he wanted to go for a partial reception of the 28e channels I believe he can do so provided he asembles a 1.2 Dish, very properly aligned on the Sat. Hopfully this clarify everything to everyone satisfaction. (Phew Chr*st have to think in Maltese and type out everything in English, quite a headache in situations like this, I can tell you m8)
athens, dish, required, size
[IMG] code is Off
