Gibertini 85cm - QuestionsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 13-12-2003
How strong is the feed arm & multi LNB bracket for the aluminium Gibertini 85cm? I would like to get 13, 19 & 28 from a single dish, and am wondering if it is really strong enough for 3 LNBs, in the North of Scotland, and all that the weather in this part of the world can throw at it? Also, does the bracket allow vertical adjustment of the LNBs? The only photo I have seen of it (not a very good photo - does anyone have any good photos?) seems to show a flat bracket, with no easy/good vertical adjustment option, other than bending the bracket? I seem to remember the Visiosat dishes (are these still available?) had, what looked like, a good quality bracket, that allowed each LNB to slide up or down, then lock in place. Can this dish attach to a horizontal pole? My existing dish is attached to an ‘L’ shaped pole, that has the short, vertical part in the wall plate, with the dish connected to the longer, horizontal part. TIA. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | These three satellites are possible off the Gibertini 85 with offset bracket by bending the bracket to suit. The dish will easily attach onto a pole type mount. | ||
| 85cm, gibertini, questions |
