Atlantic Bird 3 alignment
Old 29-07-2009   #1
My System: 60cm dish Technomate 1500
I'm trying to align to the above. I was on Hotbird 13E and I can pick up Thor @ 1W , but I don't seem to get AB3.
I'm using a signal meter which appears to climb as I swing further west from Thor, but the technomate rxr reports no signal/quality gain on any of the satellites.
The LNB skew setting on the satellite is 1 to 5. I think it was on 3 for Hotbird, but I don't know what it should be on for AB3.
Am I doing something wrong or is AB3 slightly more elevated than the other 2, and hence why I'm missing it?
lunartuna is offline   Reply With Quote
Old 29-07-2009   #2
Toute Ronde Bon Oeuf
Tivů's Avatar
Real name: Gordon
AB3 is about the same elevation as 1W and is a massive signal. Skew is not too critical, but should be more or less zero (ie LNB upright).
However, the numbers you quote suggest you are using a Sky LNB and you can't get zero Skew with those as they are designed for easy adjustment around the required Skew figure for 28E.
No matter - I use a Sky Minidish/LNB for AB3 (Well, SWMBO does, to be strictly honest!) and it should be fine with it adjusted as near upright as it will go.
BTW, if you are using a toy Sky Dish, I'm surprised you are apparently getting 1W .........
Some details of your kit required, methinks
Tivů is offline   Reply With Quote
Old 29-07-2009   #3
satelliteman's Avatar
Real name: Paul
If you are using that type of LNb, it's possible to cut away some of the plastic to allow a further adjustment to the skew.
satelliteman.
An Installers Choice
Follow us on
Old 29-07-2009   #4
Cheers for rapid response. Kit is Technomate 1500 CI rxr, plus a 60cm dish with what looks like a Raven BJ21 LNB.
It worked fine with Hotbird, plus I get a very good signal/Qual off Thor, both pushing 75%. However, with my 6yr old daughter and a walkie talkie watching the TV and signal and me up the ladder, she reports no change to AB3 as I swing round through what must be 20 degs.
All I can think is that maybe the elevation is tanked, as I don't seem to be able to pick up anything West apart from Thor.
(Maybe I should swap with my daughter and she'd have more luck up the ladder!)
Old 29-07-2009   #5
Amo Amas Amant Admin
Topper's Avatar
Mmm
If the pivot point is not 100% vertical in all planes you will get signals not being received from certain sats in line with the pictures below
edit oh dear looks like that file is corrupted, I'll try to find another copy
There you go should be able to see that
Atlantic Bird 3 alignment-arcadjustjp-jpg
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
futumsch (31-07-2009)
Old 31-07-2009   #6
T minus 1 day til the garlics arrive and I still am having grief.
I think the prob is the receiver. When I pick up Thor 1W, I swing the dish and "see" the satellites on the signal meter but when I look on the TV the receiver isn't showing them with any increase in sig/qual.
There are some settings for DISeqc1 and 0 or similar. Do I need to alter any of those or the freq?
It's all very frustrating as I seem to "see" numerous sats on the meter but only my orig Hotbird 13E and Thor 1W on the wretched Technomate.
alignment, atlantic, bird
[IMG] code is Off
