Why does it rain when i go to set up my dishInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Regular Member Join Date: 05-03-2009 Location: UK
My System: -------------- |
Having just moved home every time i go to go outside in the garden the rain clouds come along and it rains for the rest of the day, The only thing i have got done in a 2 inch pole in the ground ![]() ![]() On another note what do you guys think of H-H diseqc mounts over a polar mount and linear actuators i want to put my channel master dish up but and thinking of dumping it for a 1m dish and h-h mount. | ||
| | #2 | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. |
2. Nothing at all wrong with H-H Mounts provided they are conservatively loaded. | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Keep the CM and fit the polar mount/jack, much stronger in high winds. | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5šN, 0.5šW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | What size is the Channel Master? 1.2 metres or less a 1224 motor will be good for that if you can still find one. Polar mount + actuator is probably the most stable. Diseqc and a big dish is great for those that have plenty of public liability cover. | ||
| | #5 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #6 | ||
My System: -------------- | I have 2x 1.2m channel masters and 1x 1m channel master the polar mount fits both size dishes the dish will only be around 100cm high of the ground. Are diseqc motors really that bad . | ||
| | #7 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Diseqc motors are fine but are not designed for the wind loading associated with big dishes. By all means use a Disecq motor on a big dish, but expect to replace it after every big gale when the internal gears have stripped | ||
| | #8 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yep, the dishes are heavy, not ideal for a DiSEqC motor. If you already have the polar mount then fit that, failing that a 36v HH 1224, if you can find one | ||
| | #9 | ||
My System: -------------- | Are the really that bad if they are why do all the sat shops online sell them Where i live the wind rips through here n the winter the valley acts like a wind tunnel | ||
| | #10 | ||
My System: -------------- | If i had one of these disecq motors i know i would have to change the dish that is not a problem. looks like i might be better off with new 18inch jack to go with the current mount i have also heard they no longer make the 1224 mount. | ||
| | #11 | |||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | eg They are often specified for use with "up to 1.2m" Dishes. That's all fine and dandy, but some Dishes are mighty heavy and some are less so. Also, the extent of exposure to the wind is a major factor. I started with an 80cm Orbital on an H-H Motor on an exposed wall, but then refitted it with a Triax 1.1m. It lasted two weeks before I put the 80cm back and now the 1.1m is on a Patio Mount in a sheltered spot but still on an H-H Motor (For no better reason than I had one spare!) I took it off the wall because I was not at all happy with the treatment meted out to the Motor stub in anything above a moderate wind. Yet where it is now is absolutely fine. So H-H Motors are not intrinsically bad - you just have to be sensible with them. What the true cut off is in Dish size depends upon the circumstances, but around 1m can't be far off the mark - but even then, only for an Aluminium Dish, not a Steel one. You want big Dish - you go 36V! You only want strong Satellites (of which there are enough), use a smaller Dish and H-H. | |||
| dish, rain, set |
