Antenna motors - power consumption
Old 03-08-2009   #1
jamie1992's Avatar
My System: Standard Sky Digibox and Metronic analogue receiver (made in 2008), receiving Astra 19.2E
When the power consumption figures for a DiSEqC dish motor are quoted, does these figures include the power drawn by the LNB itself?
eg. A Fortec Star HH42 is quoted as drawing:
50mA (Standby Mode)
200mA(Normal)
350mA (Max.)
But a typical LNB can draw 120mA - leading to a possible total consumption of up to 470mA (one of my receivers is rated at just 400mA maximum).
Also, what is meant by the three modes - standby, normal and max?
Thanks,
Jamie.
jamie1992 is offline   Reply With Quote
Old 03-08-2009   #2
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
50mA (Standby Mode)
200mA(Normal)
350mA (Max.)
Thanks,
Jamie.
No, the quoted power consumption is for the Motor alone.
As for the Motor Modes:
Standby = Powered up but not executing a demand to change position (ie Simply the quiescent consumption of the on-board electronics)
Normal = Moving with 13V supply (ie Vertical TP selected)
Max. = Moving with 18V supply (ie Horizontal TP selected)
Inevitably, as 13/18 V is used for LNB Polarity Switching, there is a concomitant effect upon the voltage presented to the Motor; This becomes obvious in practice as the Motor runs faster when you select a Horizontal TP (Neat trick for getting from far West to far East a tad quicker ........) !!
Tivù is offline   Reply With Quote
The Following User Says Thank You to Tivù For This Useful Post:
jamie1992 (03-08-2009)
Old 03-08-2009   #3
Tivù's Avatar
Real name: Gordon
Further
Don't worry to much about the current sourcing specified for the Receiver: Motor Duty Cycles are relatively short, so any overloading is short lived and I've never heard of any Box failures resulting from this.
Old 03-08-2009   #4
jamie1992's Avatar
Thanks for the info, Tivù.
One last question:
In addition to my DiSEqC 1.3 digital receiver, I have an analogue fixed-dish-only receiver which shares the same dish via a manual LNB switch.
I figured I could position the dish using the digital receiver, and then switch over to the analogue one. Would this work? Or would the sudden lack of DiSEqC signals make the motor unit malfunction?
Old 03-08-2009   #5
Robbo's Avatar
Real name: Mark
No, it would be OK, the motorised dish would stay where it was. The Diseqc commends are only sent when the receiver needs to change something.
When you switched the digital receiver back in, it would just be the same as it was before you switched it out.
Now, two receivers controlling one motor using a manual switch would cause minor problems.
Old 04-08-2009   #6
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
i only know about this,that the combination,staab HH 100/120 motor,and invacom lnbs are not good,it happen to times,that the diseqec motor destroy the lnb,and i was wondering,how this can happen!
in the beginning of the first movment of the motor,and the stop,the voltage,seems to be to high for the incacom lnb,and then,it stop working,also long time ago,with a satscan motor ,and a old grundig twin lnb that take 250 ma i recogneized,that the receiver often swtich off,because the power that the lnb takes was to much for the motor!
mostly cheap receivers,espasaly from head the modell 790,i recogneized,that it can happen,that some lnbs,that taking to much power,will not work ,when the output,of some receivers is not enough and the cable to long,i put the same cable on a other stb and it works,i see this only one time,in combination with an older lnb and head 790
Turok is offline   Reply With Quote
Old 04-08-2009   #7
Trust1's Avatar
I've had the same problem with my Nokia 9500 and Moteck diseqc motor .
Turning on a hor. TP (18 V) especially coming from positions far east or west , did reboot the nokia . (error LNB short)
This kills 2 lnbs , probably tried the nokia during turning to "keep-up" the lnb power but at the moment the motor stops , there is an "overshoot" that kills the connected lnb .
Therefor a made a third connector at the motec , powering the Relais contacts with a separate 15 V power supply .
My soldering iron is smoking all the time .
Gr. Trust1
Trust1 is offline   Reply With Quote
Old 05-08-2009   #8
Turok's Avatar
Hello!
looks like,the old lnbs,are more resistent,against,to high voltage,during motor startup,but the need to much power,and the newer one,are more sensitive of high voltage!
but what would be the reason,that only some lnbs,with some stbs combination make problems,
i dont know!
when the power taking,is exactly the same,on the lnb side itsef
Old 05-08-2009   #9
Tivù's Avatar
Real name: Gordon
Originally Posted by Turok View Post
Hello!
i dont know!
Guesswork only: Does the Motor corrupt the steady DC waveform somehow, as it passes through to the LNB? Even if it did, I can't really see how that would be likely to do anything more than perhaps cause a momentary glitch. Curious, this.
Old 05-08-2009   #10
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
I've often had receivers temporarily trip when powering a motor, lnb and meter (which probably just takes it over the threshold).
Low Profile is offline   Reply With Quote
Old 05-08-2009   #11
Turok's Avatar
Hello!
is there a technical solution avalible,like a power blocker ,that only blocks a little bit,between the cable and the lnb,it should not block the complete voltage,like a protection,for over voltage to the lnb,how you would realeized this?
Old 05-08-2009   #12
My System: 80cm dish, Pace MSS500 (analog) 19e 1m dish, SG-100 motor, Dark Gold 0.1. Pace MSP 200, Humax F1 VACI
I've never seen any off the shelf inline overvoltage protection other than for lightning protection, but you would need to open up your LNB and put an 18V zener protection circuit in there. You would need to do this after the bias voltage is split off otherwise you could upset the RF performance of your LNB. Unless one is proficient at electronics, it's not worth it.
futumsch is offline   Reply With Quote
Old 05-08-2009   #13
Trust1's Avatar
Seems to me , its easier and better to do that in the motor !! (for future lnb's)
Tonight I'll search for a topic on Sat4all about a lnb power-booster , i know there was a posting long time ago .
Gr. Trust1
Old 05-08-2009   #14
Turok's Avatar
how about the waterproof,after openend the motor?
Old 05-08-2009   #15
Trust1's Avatar
I didn't seen any diseqc motor yet with a gasket or whatever , the top-part fits tight over the bottom-part
Gr. Trust1
Old 05-08-2009   #16
Trust1's Avatar
I found the pics on my own drive , didn't build or test it myself .
Antenna motors - power consumption-diseqc-booster-jpg   Antenna motors - power consumption-booster-house-jpg
Gr. Trust1
antenna, consumption, motors, power
[IMG] code is Off
