Help!!! joust bought a SilverCrest Satellite and it's shows 14% signal Quality...
Old 03-08-2009   #1
Real name: Chals fathal
My System: Digital Camping satellite system
Unhappy
Help!!! joust bought a SilverCrest Camping Satellite system and it's shows 14% signal Quality... and intensity 0 - 73 - 82 but it's says No Signal?? and if I unplug the coaxial cable it's always shows the same to 14 %??? is this normal??
I try everywhere but still the same... 4 hours but nothing change :/..
please help it will be nice from you
From Lidl*
Model SL 65 / 12
DigitalPoint is offline   Reply With Quote
Old 03-08-2009   #2
Toute Ronde Bon Oeuf
Tivů's Avatar
Real name: Gordon
That's because you haven't correctly aligned the Dish to a Satellite position.
The readings are doing nothing more than indicate you've actually got the LNB connected to the Receiver.
Assuming you are trying in the first place to get UK stuff off 28E, then the Dish face need to be nigh on vertical and you need to align very carefully: It's one of those tasks than can seem insufferably difficult until you've managed it the first time - then it gets much, much easier!
Tivů is online now   Reply With Quote
Old 03-08-2009   #3
Unhappy
I have this "Satellite locator compass" and I've already aligned to "Astra 1" but still the same the intensity shows up to 81 % but the signal quality still the same 14 sorry I'm new about this but it's is normal that it show 14% even without a coaxial cable?? plugged in?
Old 03-08-2009   #4
Tivů's Avatar
Real name: Gordon
Yes.
The Quality reading is the one that really matters - a default reading such as you've got indicates you are not aligned, let alone to a specific cluster like Astra 1. The proof only comes when you scan and actually get some Channels - even then a standard error is to be "on the wrong Satellite". ie Similar Transponder parameters are used on different positions so if you scan a pre-store list apparently"belonging" to one Satellite, whilst you are actually pointing at another Satellite, you will get some results - but not the ones you expected!
You are looking for a needle in a haystack that is 24,000miles away: Any error in either the direction or elevation of the Dish means you will miss the Satellite by miles and miles and miles ............... so gentle movements of the Dish only (No waving it around!) and lots of patience.
Old 03-08-2009   #5
Smile
Originally Posted by Tivů View Post
Yes.
Ok I've already done what you say and I'm very patience LOL
but I try to auto Scan and I always get this message "No programs found"
Old 03-08-2009   #6
Tivů's Avatar
Real name: Gordon
And you will continue to do so until you actually get the Dish aligned to a Satellite .......................
Have a couple of litres of Sangria (Just spotted your location) and go back to it tomorrow
Old 03-08-2009   #7
Site administrator
Analoguesat's Avatar
You are only correctly aligned if you get some channels showing.
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 03-08-2009   #8
satelliteman's Avatar
Real name: Paul
Thread moved to correct section.
satelliteman.
An Installers Choice
Follow us on
Old 03-08-2009   #9
Smile
allright
One more question where is the best place to place the dish ?? on the roof? or?? because now I place it on the kitchen :/ but well still the same lol.... 14 % signal quality and intensity 0 - 73 - 82... Auto scan error message " No program found and .. I see my neighbor hood watching movies lol...
Old 03-08-2009   #10
My System: Up and running -> FR Penta 85 dish, TM-02 twin LNB, TM-2300 motor, TM-5200D receiver
One thing that happened to me when aligning dish was that I had a dead transponder and just couldnt figure out how I was getting same signal all the time no matter what way i moved dish. Make sure you have an active transponder on your reciever when lining up! Check out lyngsat.com to make sure the transponder is live for the satellite your trying to get.
LoMax is offline   Reply With Quote
Old 04-08-2009   #11
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Are you using one of those piddly plastic dishes that come along with the Lidl camping set?
I tested one of those out over the weekend. They are complete rubbish.
compufunk is offline   Reply With Quote
14%, bought, joust, quality, satellite, shows, signal, silvercrest
[IMG] code is Off
