Technomate HH motor /Silvercrest sl65/12Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 15-07-2009 Location: west london
My System: looking to install a system technomate hd with motorised dish set up and enjoy |
Hi guys I need some help on the this set up to recieve the satellites pre programmed in the sat box their are about 8 I followed tutorial on how to set up the motor and sat dish . I can locate Astra 28.e, Hotbird Astra19 by manually rotating set up around the pole and adjusting the elevation on the motor and angle on the dish Am i right in saying when you get a good signal on any of the above sats, the rest should be set? as i actuate the motors position it does not come across any other sataliltes or do i need to set the reference point on the motor to 0 and pick a specific satellite to start from, I have a 90cm mondeal dish i am experimenting with the silvercrest before i go out and buy the dear stuff Your help please Meep | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | As per the guides, you zero the motor, set your latitude on the motor body and align to your nearest due South satellite, which in your case is 1W. http://www.satellites.co.uk/satellit...pictorial.html You align by moving the whole assembly on the mast and the dish vertically. As you are slightly off 1W, you will need to go into USALS setup, enter your latitude and longitude and send the dish to 1W first. | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | If your Mount is perfectly plumb, and you use USALS, you don't need to set up on your South Satellite (though many people still prefer to do this), as it is sufficient to fix any point on the Arc. Having done so, you'll find that the Motor body is actually facing South. It's the same effect as the South Satellite method, but achieved by a different route. If you don't use USALS, the South Satellite method is still de rigeur. But even if you use the "quick" USALS method, it's always worth going to a potentially weaker Satellite once you've fixed a point on the arc, as the stronger Satellites can lead you to false conclusions about the precision of your alignment! | ||
My System: looking to install a system technomate hd with motorised dish set up and enjoy | thanks for the reply When you say W1 does that mean Thor1 satellite? My reciever does not have that one stored unless you have an idea how to input the settings to create a new satellite thanks meep | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Try Intelsat 10.02, the Thor satellite is Thor 3 and 5. | ||
| | #6 | ||
My System: looking to install a system technomate hd with motorised dish set up and enjoy | hi well i did what u said i found Thor! I thought if i could add the frequencys some how i might be in luck, so i fiddled about with the tuning menu found a way to add a sat typed in its name and frequency done an update i have the mighty Thor! from this point it was just a matter of manually moving the motor to the sat i want a quick update done I have already got atlantic bird 3 so i got about 8 sats stored it has given me confidence to do a proper install with the better gear later But really its this forum and the guys within that really helped thanks i will be back shortly with some pics meep | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Well done Meep. | ||
| | #8 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Excellent - have fun with all the weird and wonderful stuff there is out there for free! | ||
| motor, or silvercrest, sl65 or 12, technomate |
