Noob trying to find thor.Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
| Member Join Date: 15-07-2009 Location: birmingham uk
My System: Motorised 1.1m, Dm500s | Cheers mate, i understand the 38 now. Crap manual. 35 - 7.5 = 27.5 for declination angle i assume, then i just play. Bet i still get sod all on the dreambox lol. | ||
| | #27 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | As said, your probably just finding it difficult to locate 1W. | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | danielb (06-08-2009) |
| | #28 | ||
My System: Motorised 1.1m, Dm500s | I have another question. (If i ever get this done ill write a wallys guide)How do you distinguish between satellites? Do you have to scan, then whats found and then match them up online? Also the signal bar on a dreambox, will it increase no matter what satellite is inline with the dish? For example; if i have thor selected on the menu and I inadvertently line up with a satellite a few degrees east or west, will the signal level on screen still increase? or will it only increase when thor is inline? Many thanks. | ||
| | #29 | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5šN, 0.5šW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #30 | |||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | This is why you choose a transponder that is not active on neighbouring satellites. That way your signal strength/quality bars will only move when you zero the correct satellite. | |||
| The Following User Says Thank You to Huevos For This Useful Post: | danielb (06-08-2009) |
| | #31 | |||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | No need, existing members beat you to it ![]() The Ultimate Idiot Guide! For Idiots by Idiots!Answers,Questions,Tips + Tricks: RTFM! | |||
| The Following User Says Thank You to Topper For This Useful Post: | danielb (07-08-2009) |
| | #32 | ||
My System: Motorised 1.1m, Dm500s | Thats the idiots guide, too advanced for me ![]() Well that was easy. Found thor (I assume) 95% signal, i told the dreambox to go to astra 28 and i got 94% there too. lol 800 ish channels, bskyb service, so does that mean im aligned correctly. BskyB is on astra 28 i hope. I assume i can get the dreambox to operate using my genuine subcription card with a bit of messing. Thats my next step. Cheers all | ||
| | #33 | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Just about. It's a good idea to check Satellites at the end of the Arc. 42E (of the worthwhile Sats), probably further, depending upon your line of sight and 58W at the other end. Also try weaker Satellites like 10E etc. just to demonstrate stonking performance across the board! Edit: I've just scrolled back to find out you've got a 1.1m Dish, so do try BADR at 26E. | ||
| | #34 | ||
My System: Motorised 1.1m, Dm500s | Bit of break up of some channels on 26e. I dont wanna tweak ityet because im not sure what satellites ill be using yet. On a 1.1m should all channels on 26e by fine? | ||
| | #35 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | | ||
| | #36 | ||
My System: Motorised 1.1m, Dm500s | Me again ![]() I found a free to air football match on LJs. The details are attached. This is on the thor satellite, i noticed my previous automatic scan hadnt found the channel. So i tried a manual scan and sure enough new services were found. Unfortunately its unwatchable, a fluctuating ber value and SNR. 1. Why didnt the dreambox find it on the automatic transponder scan? 2. Am i likely to recieve this with tweaking? 3. I now assume some transponders are weaker than other on the same satellite? Thanks again | ||
| | #37 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Should get Tp 11.919 (Mbc) using a 110cm in B'ham. | ||
| noob, thor |
