signal strength and signal qualityInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
| Specialist Contributor Join Date: 12-01-2005 Location: naples italy
hello, i was looking at this and what satellite are you trying to receive? if you are trying to receive sky uk or the free view like bbc unless you have a defective lnb or a verry old one all lnb's in europe are compatible with every satellite system. they all have 2 local osc. andy all switch with 14 v and 18 v and they all use the 22 khz upper band and lower band. if your box is defective it could cause the problem. take your box to a friend and see if it is working there. if it works ok then the line could be verry old of the lnb could be bad. the lnb costs about 5 euro now a days. hope this helps ralph | ||
| | #27 | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. |
This is the LNB he is using, and which we have advised he replaces with a Universal type | |||
| | #28 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. |
PS. please upload your photos by using the manage attachments button at the bottom of the post template. | |||
| | #29 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | SMW LNBs and feedhorns are normally 4-hole fixing. I managed to screw my SMW feedhorn onto an Invacom C120 screwed to just the four holes with no problem - as long as the O-ring seals up OK. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | rolfw (18-08-2009) |
| | #30 | ||
| Member Join Date: 07-12-2008 Location: 63° 19' 00N 13° 49' 60E Sweden
My System: 1.8m prime focus dish MTI AP8-TW 0.6dB lnb Pace sky reciever | Sorry to bring up this old post, As you can see the problem was that the lnb was an old analogue. I've recently installed a digital variant and now I can view channels on astra2d. Now I'm only getting at best 25% signal strength with the digital lnb compared to 60% signal strength with the analogue lnb. Someone suggested that I could change the default transpoder to 12.207 V for the analogue lnb. Would this work? Thanks | ||
| | #31 | |||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | No mate the analogue lnb was not designed to receive signals at that frequency so it will not period, you will just need to tune your new lnb by focussing back and forth and apply the correct amount of skew, assuming of course your dish is aligned correctly. The default transponder is to do with the stb not the lnb | |||
| | #32 | |||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5šN, 0.5šW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | |||
| | #33 | ||
My System: 1.8m prime focus dish MTI AP8-TW 0.6dB lnb Pace sky reciever | Hello all, Thank you all for your input. Great forum. ![]() I just noticed that this thread has an error. I'm talking about signal strength, but I actually mean signal quality. Still my digital lnb works fine even though the signal quality is lower (25%) than what the analog lnb is producing (~60%). I just figured that cosidering my location (lat63n lon19e), that one should be trying to maximise the signal quality. Can anyone recommend an lnb that would give me a better signal quality? Price is a prohibiting factor, so I suppose it's value for money that counts. Incidentally I paid 130SEK (~Ģ10) for the current lnb I'm using. You can see some photos of my set up at this thread I posted a couple of days ago. wind wind wind ! | ||
| | #34 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Well Signal Quality is indeed the most pertinent factor. However, unless I am mistaken you are using a Pace Sky Digibox? In which case, the Metering is very vague and relatively meaningless in numerical terms. All you can do is maximise what the bars do register, regardless of the apparent percentage. My neighbour has a Sky Box that indicates zero Quality, but my own Receiver attached to his system tells a different story. Bottom line: If you have lock even in poor weather, you've done the job. If you really want to squeeze every last drop out of the Dish, then use a decent meter or a Receiver with meaningful metering. | ||
| | #35 | ||
My System: 1.8m prime focus dish MTI AP8-TW 0.6dB lnb Pace sky reciever | Hello The signal quality figures I quoted are readings from my satellite finder. (Horizon HDSM USB Digital Satellite Meter) Good quality. I trust the figures I'm getting from this device. Sorry I didn't make it clearer where my signal quality figures where from. | ||
| | #36 | |||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Aha. Thanks for the clarification. It's more likely I didn't recap the entire Thread properly than any omission on your part! But do you have good stable lock on all the Channels of interest? | |||
| | #37 | ||
My System: 1.8m prime focus dish MTI AP8-TW 0.6dB lnb Pace sky reciever | Yes I have a good stable lock and I can get the BBC, which was my primary objective. However I cannot get good signal quality on Astra2a. 10% I was suprised at this as the footprint charts show that it should be easier to get astra 2a than astra 2d | ||
| | #38 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | You are still missing what everyone has been telling you all along. Your old LNB was a standard, not a universal. That means when the receiver puts on the 22khz tone to get the LNB into high band it just sits there in low band, i.e. looking at the wrong frequency. So when the level says 60% that is for some part of the spectrum that is completely non related with the default transponder, which is why the box wouldn't fire up with that LNB even though you were getting some magnificent signal level. | ||
| | #39 | ||
My System: 1.8m prime focus dish MTI AP8-TW 0.6dB lnb Pace sky reciever | Thank you Huevos for putting it into plain English for me. As you can see I'm a newbie on this. Still I'm hocked on this satellite stuff. Any suggestions where I can read up more on the subject on the net? For newbies of course. Thanks.. | ||
| quality, signal, strength |
