Originally Posted by Malard Thanks Telia, i've sourced the dish from the UK supplier, thats not the problem just need to get an LNB and feedhorn, does anyone know if the boss and rods from the dish are included with the dish or if i need to get them seperatly? |
A kingpost is going to take at least a day to set up correctly as the concrete needs to set fully around the studding. Then you are looking for a day to install the dish as per instructions. So it is not really necessary for the LNB / feed to be available until the weekend.
You could always install what is arriving, and swop it over once the dish is fully aligned, so no need to delay things.
As for people stocking C120 CM feeds, one of the forum sponsors might look in tomorrow morning and send you a PM.
