How can I calculate signal strength decrease for non-focus sats, in multifeed system? | | Let's say, I have a dish pointing at 13E. I've mounted another LNB on it, pointing on 5E, adjusted to maximum signal strength. What will be decrease of signal strength in dB in such case? is there any way to calculate it mathematically?
For larger/brandname dishes, in user manual you can find sidelobe attenuation level, which can be used as reference for placing additional LNB. But generally, such info is available for large (over 180cm) and high-end dishes only, leaving most consumer dishes market outside. |
