nilesatInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | 11862V always | ||
| The Following User Says Thank You to Robbo For This Useful Post: | smudger1 (31-08-2009) |
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yep, that's a strong Vertical transponder.....and a horizontal Robbo? | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | smudger1 (31-08-2009) |
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | 11919H and 12226H, that's all I can get atm. | ||
| | #5 | ||
| Regular Member Join Date: 04-09-2006 Location: Kent, UK
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | Robbo, do you get 11900V at all (on a 1m)? (Asking to assess effect of recent fec change) | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Getting a lock on it, with a signal quality level that would normally provide a stable picture, but with the fec at 5/6 , just got sound coming through and the occasional still frame. | ||
| | #7 | ||
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | Ta. Indeed the baffling thing is that while the signal level is above normal threshold one still has problems with the transponder. I should have asked a more complete question before: do you get the 11900V during the day or only at night. Having tampered with my set up, I suspect it is not 100% optimised for Nilesat --- which might explain why I don't get 11900V at all during the day ------- unless it is common e.g. if you too don't get it day time. PS someone I gave your nos (from MBC site) should have called you by now; feller in Plumstead? | ||
| | #8 | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Nah, not yet mate, but thanks anyway. I have only recently moved my dish again, and I thought it was set up pretty well, but I tend to concentrate on the MBCs as that is mainly what I want and with them of course the stonger tps follow, the horizontals of course are just a bonus as and when they are slghtly stronger at certain times in the year. I may have a look to see if I can get any better on that tp. Had you mentioned it a couple of days ago, I could have tried on a 1.2m for 11900V, but the dish is now in Lambeth, fixed on badr4. | |||
| | #9 | ||
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | Thanks again; I like keeping an eye on a couple of channels on 11900V; plus, it is my acid test for how well my Nilesat is set up. With the fec change, I have not been able to etablish conclusively whether I have optimal set up or just very very marginally short since my last tinkering. Cheers. | ||
| | #10 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | That's a god tip bigtee, I thought MBC was one of the weakest, but 11900V is weaker, thanks. I will have a tinker too tomorrow. | ||
| | #11 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Tried tweaking just for 7W 11900V, but was unable to get it any better. | ||
| | #12 | ||
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | Thanks Robbo; maybe leave it alone till it shows signs of coming to life by itself --- which happens some evenings when signal is stronger than other days. | ||
| | #13 | ||
| Member Join Date: 22-05-2003
| nilesat |
