Problems with Hellas sat 39 EastInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 02-09-2009 Location: Essex
My System: Sky+ Multiroom |
Hi Guys, Just registered on this forum after searching to find a solution to my problem. I have a "Lidl" free to air satellite setup that I have had for a while but only just got round to setting up. I'm after getting the free channels from the Hellas satellite (hence posting here!) ![]() I know that my (60cm) Satellite is pointing at 39 degrees east for certain (I'm in south Essex) but I've been unable to get any greek channels through my (Sky Line) receiver. I've selected the Hellas 2 sat in the setup and also input the Frequency of 12606 and S/R of 30000 as per the Hellas website. But a search on those settings brings up nothing. I've performed an "Auto Scan" and its found around 80 or so channels (most subscription) but NONE of them are greek! On another note the only channel I can get (Sat1 I believe its a german channel) when watching it the box keeps rebooting itself after approx 10 seconds? I assume that this is not normal, but are these 2 problems related? Any help would be VERY much appreciated! I'm stumped!!!! ![]() Thanks in advance Keith | ||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
The footprint is F2 which seems to be good enough to catch with a 60cm dish on 12606H. You should input 30000 and 5/6 instead of the default 27500 and 3/4 in the TP data fields. _http://www.lyngsat.com/hellas2.html There are two more TP's with Greek channels. Just input the parameters as listed in Lyngsat and see if you get them. Regarding Sat1 problem: I can't see it in the list. Which frequency is it? I had similar problems with my Nokia 9800S with ZDF and I simply deleted the channel. | |||
| | #3 | |||
I did input the 12606H and 30000 as stated above but it would find no channels ![]() Where do I enter the 5/6 data? I can see no option for it in my settings? Could this be why I'm not getting channels? keith | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Are you sure your on Hellas 39e? | ||
| | #5 | ||
My System: Sky+ Multiroom | Hi Satellietman Yes I am 100% sure as I've had a local engineer round who has rigged up the (60cm) dish for me and showed me the meter which was buzzing at 39 degrees East. His meter was also selected to Hellas2. I assume that meant it was correct??? Keith | ||
| | #6 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Please name a handful of received channels and their frequencies. | ||
| | #8 | |||
| Will help if you can give us few channel names,even scrambled, as suggested by Satelliteman. The Sat1 looks suspicious and you might be getting Astra 19.2E instead. What is the frequency of the Sat1 channel in your receiver? As it is rebooting after 10 seconds, disconnect the LNB cable momentarily until you get a reading, hopefully. | |||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | It is not uncommon for these small meter identifications to be erroneous, they identify by comparing two or three transponders and occasionally another satellite will have the same transponder frequencies and parameters. ![]() A list of the channels you can receive will seal the deal as to whether the meter has fibbed or not. | ||
| | #10 | ||
My System: Sky+ Multiroom | OK Guys here's the first dozen or so channels in the list $ANN (Arab) $Inter+ (ukr) $ProTV International $The Poker Channel $TVR International $France 24 (FRZ) $God TV (Engl) $Luxe.TV (Engl) $Samanyolu TV $Phoenix CNE All of the above show 12606H 30000 $Consumenten TV 24 $Humour 24/Nost.net $Nederland 24 $NGC Wild $Discovery Science $Discovery Traffic $Discovery Science $Het Gesprek $Vitaliteit $BiB $Sport1.2/Erediv.2 $Film 1.3 24h $ Geschiedenis 24 The channels above all state 12439V 27492 There are more if you need them???? Hope this throws something up! Keith | ||
| | #11 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | If those are the channels you are receiving then your dish is aligned to 23.5°e In addition, the frequencies/channels you supplied do not tally. | ||
| | #12 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yep, definitely 23.5 East, his meter has told him porkies. ![]() _http://www.lyngsat.com/packages/kabel.html _http://www.lyngsat.com/packages/canaldigitaal23.html As Satellite man says, the frequencies you list are not correct, have you played with the LNB settings? | ||
| | #13 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Not too good at the job, was he. Time to get him back and do it properly. | ||
| | #14 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yep, meters are very useful for peaking, but nothing confirms it better for me than getting the right picture on the screen. | ||
| | #15 | ||
My System: Sky+ Multiroom | Hi Guys, Thanks for your replies. I'll pass on that info to him and see if we can sort it out. I didnt ralise that these things were so flippin hard to align! ![]() When a meter gives you a bum reading it doesnt help things does it? No idea how the frequencies are wrong though? All I did was an auto scan. I think the LNB is set to universal which I assume is the default setting? There are some user settings but its not set on those. Thanks again Keith | ||
| | #16 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Not familiar with the Philex receiver and no idea of the manufacturer, but it should have a factory reset button in one of the menus, I'd recommend that you do that before scanning again (it'll clear any wrongly scanned channels and reset to default LNB settings etc) after re-alignment of the dish. | |||
| | #17 | |||
Will do that thanks! Mines a "Sky Line" one? Seems a very basic receiver which I would expect from this budget setup Also is there a site that lists all the channels and the sattelite that they are on? I can then use this when he comes back to realign so we know where we are pointing, if you know what I mean! Thanks again all I will report back when he has returned! Keith | |||
| | #19 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Robbo lives near Gillingham, Kent Keith, but it will depend on where you are in Essex as to how close he is. If you go to the site where the two links are above, you can navigate to the Hellas sat page. _http://www.lyngsat.com/hellas2.html | ||
| | #20 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | LOL,Essex is a big place, but I'm about 5 miles from the tunnel on the other side of the water, PM me if you need help.Anything within an hour, I'm easy. | ||
| | #21 | ||
My System: Sky+ Multiroom | Hi Robbo I'm not to far from the tunnel myself about 15 mins roughly. I'll give my original guy another go first and if no luck I'll be in touch ![]() Thanks again guys, great forum this is ![]() Keith | ||
| | #22 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | You can of course tell your installer to register here. Worst case scenario, we'll talk him through it | ||
| | #24 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Ok, well, I popped to see Keith4444's dish, it was a perfectly aligned dish, getting a really good signal, loads of channels. Pity they were all from 23.5E though. Now sorted of course, the original install, must have either been mad or clueless, or both. | ||
| | #25 | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| east, hellas, problems, sat |
