astra 28.2deg (sky) and hotbird at 13degrees (cyfra +)
Old 04-09-2009   #1
My System: sky box + cyfra + box
Hi there,
I want to receive signals from these two satellites, but want to do this from a single dish. I imagine I need two LNBs and two cables running from the LNBs, one to the Sky box and the other to the Cyfra + box. Few questions now. I probably should use two individual LNBs as the twin monoblocks are spaced by 6deg only, is that correct? How big the dish should be - currently I have the Sky minidish? Any suggestions how to do it?
PS. I live in Coventry and would like to avoid motorised dish, and two decoders is not a problem.
szlapy is offline   Reply With Quote
Old 04-09-2009   #2
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
You'd need to change to a Dish of around 80cm to get both Satellites one one Dish.
Even though you seem to exclude the notion, a simple alternative would be to get a second Minidish just for Hotbird.
It isn't just the small size of the Sky Dish that is the problem - It's the shape. Not really conducive to multi-LNB use for Satellites that far apart in Azimuth.
Tivù is offline   Reply With Quote
Old 04-09-2009   #3
Robbo's Avatar
Real name: Mark
It can be done on a Sky zone 2 dish,if you were desperate to keep the dish as small as possible, but not optimally, an 80cm would do it easily though. You could split the difference or bias towards Hotbird a touch if needed, for the focus.
Correct, a monoblock, has a fixed separation eg 6 degrees on an 80cm dish. Though would be no good any way because you have two receivers, and its the wrong separation.
Old 05-09-2009   #4
I would be happy with 80cm dish, as long as it is only one dish and not two. So there is a good chance that 80cm dish and two individual LNBs will do the job, correct?
Old 05-09-2009   #5
rolfw's Avatar
Real name: Rolf
If you can source a Raven Gemini 70cm with offset bracket, that should work fine, the dish is designed for multisat use, as is the Visiosat Bisat. I have used both for those two satellites (normally with 19.2 East as well) and they provide good solid reception.
Rolf
Old 23-09-2009   #6
My System: Sky HD box, SkyStar 2 TV card in PC. Triax TD78 with off-set bracket and 3 LNB's. Homwbrew AMD 64x2, Windows 7
Hi All, nice forum this, loads of info!
This post is exactly what i was going to ask, so thought i would reply rather than start again. Currently have SKY HD with a quad LNB and a zone 1 mini dish. Ive ordered a cheep USB receiver from Ebay just to have a play about with for now and with the current dish i should be able to get the free to air service from Astra2 and Eurobird1 if im understand things right?
My next question would be if i replace my mini dish with this dish on Ebay, will let me use an offset bracket to get Hotbird services from 13 east?
_http://tinyurl.com/n9bgdn
I would just get a 2nd mini dish to point at 13 east, but im a radio ham and already have more than enough aerials and wires strung down the garden so dont want to put anything else up if i can help it!
Thanks,
James
JamesA is offline   Reply With Quote
Old 23-09-2009   #7
rolfw's Avatar
Real name: Rolf
Cheap and nasty, but will probably do the job. I would normally use a Raven Gemini 70cm and Eastern sats offset bracket and add Astra 19.2 East as well, with a four way DiSEqC switch. Many people do similar with the Triax TD68.
Rolf
Old 24-09-2009   #8
Thanks for the input. I was working on the thought that it would be a better option than a sky zone 2 dish, without shelling out much cash.
Will look into the other dishes you mention too, cheers!
Old 24-09-2009   #9
Tivù's Avatar
Real name: Gordon
Lots of us inhabiting this Forum
Old 24-09-2009   #10
Its amazing where you bump into other hams. Was browsing a grow your own forum and met 2 there as well. Yorkshire Moores must be a great spot for radio!
73, 2E0JCA
13degrees, 282deg, astra, cyfra, hotbird, sky
[IMG] code is Off
