MultiSwitch - terrestrial antenna questionInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 |
When you use a diseqc switch where one of the inputs is a terrestrial antenna what happens at the termination of the single down lead inside the property? | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | I don't think that will work. A diseq switch is used to change between alternative LNBs or dishes. It simply won't do anything to a terrestrial aerial input as you have to use a satellite receiver to issue the Diseq commands and that won't recognise anything on terrestrial frequencies. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | I think more information is needed on precicely what is being connected and how, as the question is too vague to answer. | ||
| | #4 | |||
| | #5 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | An example model number? With a multiswitch, the input terrestrial signal is separated at the downlead with a diplexer. | ||
| | #6 | |||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | _http://www.emp-centauri.cz/products.php?page=products&id_kateg=5&id_pkateg=45 &id=284 Also, are the terms diseqc 1.1 and non-committed synonymous? And diseqc 1.0 and committed? | |||
| | #7 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Ok, had a look at that, like it. Ideal for someone with a T90, plenty of inputs. Yes, that would be a diplexer that is needed for the terrrestrial separation. Diseqc 1.0 are always committed, I think Diseqc 1.1 can be either. | ||
| | #8 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | An example of triplexed outlet plates, these are screened and come with a couple of different connection methods from different suppliers. _http://www.tvlink.co.uk/wallplate.htm | ||
| The Following User Says Thank You to rolfw For This Useful Post: | Huevos (07-09-2009) |
| | #10 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Also these... | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | Huevos (07-09-2009) |
| | #11 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | How much of an insertion loss are we looking at here? I mean, if the tv or sat signal were weak would you avoid this method? | ||
| | #12 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Typical insertion loss around 0.5dB on UHF and 1.5dB on IF. Also there will be an insertion loss on the DISEqC switch. | ||
| antenna, multiswitch, question, terrestrial |
