Advice on dish and lnbInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Regular Member Join Date: 23-04-2009 Location: Dublin
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT |
Hi, Getting a 90cm motorised system installed next week and the installer has given myself the option of selecting either a Globo or Faval dish and either of the following lnb - inverto, Titanium, Faval, Chess or Thomson. I am primarily going to be using the dish for Digitalb on 16E but that will no doubt change very quickly with the multitude of options the motor will give. I would appreciate any experts advice as to what would be the best selection given the choice on offer. Much appreciated. | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! both dishes i dont know ,not avalible here! digialp should be very strong now,since the satellite has been replaced! in the meantime,the smart titanium lnb,has 2 diffrent version,the first one and the 2.edtion! on some internet reports i read,the first titanium performs a little bit better,then the 2nd! i would recomended the inverto lnb! the black edition is the latest,and performs where good! white edition also okay! at least the dish question,got to the homepage,of both companys,and look the datasheet,of both antenna,then you can see the difrence! | ||
| | #3 | |||
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT | I went to the faval website and looked at the dish but it did not have any info and a google of globo just returns the brazilian tv station and papers along with the odd receiver. I agree with the inverto myself as I have heard good reports. Thanks | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Does this mean that your plans to fit a Monoblock lnb to your existing Dish have been binned? | ||
| | #5 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! Monoblock Lnbs,are not the best solution ,when the distance is only 3 degrees between astra and 16e 23,5 east and 19.2 east is okay,but this lnb type are not so much spread then the normal astra hotbird versions! here are many albanians,that have a lot of problems,receiving astra and 16 e,also with selfmade multifeed holder at the same time,when the antenna is not install exactly,the signal on one of each satellite is very low! | ||
| | #6 | |||
| | #7 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | in the past,hirschmann offers a motoreized multifeed set,where could move,the lnbs,with the remote,exactly,in its optimal position,but this works only so long,on the satellites from 19.2 east to 5 east,and when the elavation angel,has been changed,the system,was on his limit!on todays monoblock lnbs,its not very adustialbe ![]() dont install the cheap inverto quad lnb,for 29€ i recogneized in my test,that the signal is loose a lot,on the other inputs ,when another person watching at the same time,a programm,when signal is strong enough,you would not recogneized it,the quad invacom for the double price ,has defenetly better components inside then the new inverto quad,when you install singel or twin,without quad or monoblock inverto is the better choice! thats all i can say to this,,good luck,inform us,when the setup is complete! | ||
| | #8 | |||
| | #9 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Wise move! Good luck getting it sorted | ||
| advice, dish, lnb |
