channel master dishes
Old 15-09-2009   #1
My System: Motorized 1.1 triax, Dreambox 500s, Protek 9600, Technomate 1000 d super.
I am just about to buy a 1.2 channel master. The supplier i was talking to said that he might not be able to get the andrews channel master that it was sold to asc as we know, but then sold to raven. he said the newer models are a bit lighter and can go on a 2 inch pole instead of a 3 inch pole. I was on the asc/raven websites and seen the pics the azel mount seems smaller. but i think it looks good. I just want to know is the asc/raven version of the channel master the same.
jpsr is offline   Reply With Quote
Old 15-09-2009   #2
satelliteman's Avatar
Real name: Paul
It might be the 1.2m ASC valuestar dish.
satelliteman.
An Installers Choice
Follow us on
Old 15-09-2009   #3
timbo86's Avatar
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn.
Yes, possibly a ASC Valustar, although the 1.2's I have been using recently only fit on a 3inch (76mm) mount.
Adaptor rings may allow then to fit on a 2 inch mast?
Good dish at a fraction of the price of it's Grandparents.
IMO they perform similar, but I have just been using 40 mm LNBs.
I will maybe try one with the CM matched feedhorn to see what the difference would be.
timbo86 is offline   Reply With Quote
Old 15-09-2009   #4
The picture i was looking at was the moulded reflector version on the asc signal website. I dont want the valustar I must tell him. As its made buy asc/raven now and not buy andrews/channel master is it still the same quality dish.
Old 18-09-2009   #5
GreenmanBelg's Avatar
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA
Wink
Is coming from the North?
Look here ____http://www.satellites.co.uk/satellite/picture-members-setups-general-satellite-installations/155272-1-2-meter-arabsat-install-belfast.html
Regards JD Belgium.
GreenmanBelg is offline   Reply With Quote
channel, dishes, master
[IMG] code is Off
