SG2100 motor limits
Old 16-09-2009   #1
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards
SG2100 motor limits
Hi friends ..
I've finally brought my old sg2100 down from its mount with the intention of relocating it to service the missing section of arc from 36E to 70 East ..
However ...now that I have it ground level I figured I'd try and unlock the mystery of why it cannot get past 60 East
I've taken off the motor stock and pushed the hardware limit switched to maximum ...
I then connected it up to my HDCI2000 and tried to move to 65 degrees East (running in usals mode ) ...
The motor refuses to budge ...and the receiver reports that the intended target is outside the motors range of movement.
If I switch to diseqc mode ...I then have access to manual East West movement ...and can rotate the motor all the way to the hardware limit which is at 72 deg East or West ...
Its as though A software limit is intervening to prevent what Im trying to do ...and that this can only be achieved in diseqc mode ..
I've tried ajusting the software limits through the receiver ..but my attempts to store new limits are ignored by the motor..
..and once I'm back in usals mode the motor again refuses to move past 60 degrees ..
Is this so called software limit 'hard wired' into the motors programming ...or is it just me being to stupid to figure out whats going on ?
Obviously I dont want to remount this motor on a pole out of reach until I've sussed the problem ..
Can anyone help ?
rgds
VS
Vipersan is offline   Reply With Quote
Old 16-09-2009   #2
satelliteman's Avatar
Real name: Paul
Usals software preventing movement past 60 degs.
satelliteman.
An Installers Choice
Follow us on
Old 16-09-2009   #3
Thanks for the reply m8..
I assume you mean the software within the receiver ...and not the software in the motors micro ?
If thats the case presumably a different receiver would have different limit parameters ?
rgds
VS
limits, motor, sg2100
[IMG] code is Off
