multi sat upgrade
Old 24-09-2009   #1
My System: dm800hd
multi sat upgrade
as title really just looking to see if i'm ordering the right parts for the job here goes
ive got a new sky dish and lnb installed on a single cable runnign to my dm800hd pvr sat box and i want to have 28.2 19 and 13 would i be right in saying that i need these components?
Triax TD 4 LNB Multiblock Holder
Satellite LNB 4 Way Diseqc Switch
Triax TD88 88cm Solid Satellite Dish
MTI AP8-XT2EBL 0.2dB Universal LNB x2
ive ony got 2 lnb's there becuase it think the new lnb does a fine job for hd material now?
please any tips or advice to the parts i'm looking at
and would the triax dish be mountable from the sky arm?
cboy is offline   Reply With Quote
Old 24-09-2009   #2
rolfw's Avatar
Real name: Rolf
You can use the Sky LNB, but it isn't ideal, as it is designed for the Sky minidish, not the conventional offset dish.
Get a more substantial bracket for the TD88.
Rolf
Old 24-09-2009   #3
My System: dm800hd
so i'd need to buy another lnb or could i use the sky lnb for one of the other sats?
so i'd need a bigger mount then? which one should i look at?
Old 24-09-2009   #4
rolfw's Avatar
Real name: Rolf
If it isn't good for one, then it won't be good for another.
_http://www.sateuropa.co.uk/product_overview.asp?id=1518&catid=12&subcat=51 is a good solid little bracket.
Rolf
The Following User Says Thank You to rolfw For This Useful Post:
cboy (24-09-2009)
Old 24-09-2009   #5
My System: dm800hd
hmm i would rather buy from 1 supplier what lnbs do you think i should get for hd material?
i know they shoould be atleast 0.2db
but you must have a knowledge of whats better or best?
any input would be greatly appreciated
Old 24-09-2009   #6
rolfw's Avatar
Real name: Rolf
They're all pretty similar in performance and you are looking to receive three very strong satellites, so it isn't critical. My personal favourites are the Invertos, they do a superb multisat range which includes offset bracket and DiSEqC switch as well..
Was simply using that item as an illustration, but do encourage our members to use our supporting advertisers, as they are the ones who keep us up and running to help people such as yourself.
Rolf
Old 24-09-2009   #7
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
There is no fundamental difference between what LNB you should use for HD as opposed to SD. Any advert which says "suitable for HD" or "HD ready" is superfluous - they are just fabricating a selling point (but not actually telling Porkies, either!).
AS rolfw indicates, all new LNBs have perfectly acceptable performance. The only really issue is getting the right ones to match the Dish, Sky LNB Feedhorns are matched to Dishes that are wider than they are tall and 40mm collar mount LNBs are matched to standard Dishes that are marginally taller than they are wide.
Tivù is offline   Reply With Quote
Old 24-09-2009   #8
Robbo's Avatar
Real name: Mark
Sky LNBs on a TD78 work pretty well, especially good if you don't want to pay out for new ones. As the sats you want are strong, it is not critical. Some do require modification though, to strip off the lugs moulded onto the 40mm neck of the LNB.
Robbo is online now   Reply With Quote
Old 24-09-2009   #9
Tivù's Avatar
Real name: Gordon
Yes, the feedhorn mismatch is something that is more of a theoretical problem than a really practical one, except in marginal conditions.
But don't use a Stanley Knife for removing the surplus plastic!
multi, sat, upgrade
[IMG] code is Off
