Advice on T&K brackets - sizesInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 06-09-2009 Location: Herts
My System: not yet installed |
I hope to set-up my first motorised system shortly and am intending to buy the various bits of kit as I go because if I get the lot I will only try and have everything installed and being watched in half a day leading to a poorish install. I will be using a dish of no more than 1 metre size with a DiseqC dark or technomate motor. However as I don't yet have the dish or motor I am unsure what size T&K brackets I will require to allow full movement of the dish. The dish will be going on a south facing wall. Any advice as to choice of rawl plugs etc for mounting also most welcome and the distance between the T and K bracket. My existing sky dish is about 3 metres above the ground and I am intending to have the new dish in a similar position. Finally is a 2" diameter pole recommended, only I only have smaller diameter pole here and have seen 2" pole being sold for silly prices - 35 notes for a 2m long pole seems outrageous. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Hi Tim, Anchors bolts are fairly strong for TK fixings, also depends on the brickwork of course. Spacing the brackets will again depend on the length of the mast but as a rule 500mm minimum. See if you can get a scaffold mast, very strong | ||
| Regular Member Join Date: 18-11-2004 Location: Belfast, Northern Ireland
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. |
I would try and pole mount it above the gutter to give you a better view of the arc. Depending on what size of the soffit, normally 12 or 18 inch T & K could be used. With a 3 meter 2inch steel mast. Steel masts are not expensive, most suppliers will cut them by the meter and shouldn't be anymore than £15 for 3 meters. Make sure you get the best motor you can afford as a 1 meter dish is heavy and it will act like a sale when it's windy. The Dark motor comes highly recommended. Or you could use a 24 inch T & K and have the dish lower down. 24 inch brackets should give you enough clearance depending on your location to true south. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | If you use something like a Fracarro Penta 85 and your wall is actually South facing with a clear line of sight, then 12" brackets will suffice and a small length of scaffold pole as suggested above. I used to get 6ft lengths from a local scaffold company for a fiver each, he charged the same for 10ft lengths, just had to make sure that he gave me new ones. ![]() Motor wise, I prefer the Moteck or Technomate. | ||
| | #5 | ||
| Regular Member Real name: Pete Join Date: 13-12-2008 Location: Lower Normandy, France
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema | Hi Tim, My system is mounted on a South facing wall, below the gutter and is on 12" T&K's. Brackets are 1 metre apart, pole 4cm x 1m 50cm, though a store purchased one rather than a scaffold pole. Dish 1 Metre and can see the arc from 50°E to I would guess 50°W if the trees weren't in the way!! Pete | ||
| | #6 | ||
| Specialist Contributor Join Date: 29-06-2009 Location: UK
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards | Hi .. Used 2 mtre Pole and 2 Ts +2 Ks on my setup motorised 1.1 mtre dish.. Mainly due to the heavier steel dish.. Also left room for a fixed dish at a later date. The brackets were 18 inch ..but would easily have got away with 12 inch brackets...but went down this route because I wasn't sure I'd miss the soil stack at extreme west I used anchor bolts rather than rawlbolts .. ..as its old brickwork and I didn't want to be doing repairs later. I've since fitted another dish to get the Eastern half of the arc ...on another south facing wall 20 mtrs to the west.. This motorised dish was only 80cm and was confident 12 inch T & K's would be sufficient .. Indeed there was room to spare /clearance to the wall.. rgds VS | ||
| advice, brackets, sizes, tandk |
