Old Sky Analogue Dish and FortecInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 26-11-2007 Location: UK
My System: FTA Fortec HD Satellite Receiver, minidish, only aligned to 28.2 |
Hi all I have an old analogue dish still on my house with cable. As an experiment I connected it to my Fortec Passion and did a scan on 19.2e as I seem to remember that was the old alignment but cannot pick anything up. Could the dish/lnb be totally beyond use now or am I setting the scan wrong? I did change LNB type to 9750 in the settings on the Passion. Thanks in advance Kyle | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Its could well be an old 10,000MHz lnb. | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | Very old sky dishes, as mentioned by AS usually have 10GHz, later ones used "Enhanced" 9.75GHz LNBs and then followed by Universal 9.75/10.6GHz LNBs, your best bet is to shimmy up a ladder (if the dish is low enough) and see if the LNB still has it's label and is readable, or, post a photo of the dish and I'm sure we could guess which LNB is fitted... ![]() But as a rule of thumb, 10GHz or 9.75GHz is the norm, and if that picks up nothing, it's either a duff LNB or the cable's shot... | ||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | |||
| | #5 | ||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | Looks like a Cambridge Enhanced or Universal to me, most likely Enhanced going by the age rust on the dish... ![]() Though, I think the cable's pretty much shot as there's no waterproofing on the F plug on the LNB, so water's probably gotten in and damaged the copper shielding... ![]() But, if the dish is easily accessible, you can replace the cable (if the LNB is a Universal, otherwise it's the hacksaw treatment!!!), and use self-amagumating tape to seal the connection up, Cambridges are pretty reliable LNBs, so should still work... | ||
| | #7 | ||
| Specialist Contributor Join Date: 12-01-2005 Location: naples italy
hello, looks like a old cambrige. for the 4 euro for a new lnb i would change the lnb and check the f connector as well. if the cable is cracked or broken you should change this as well. th e digital receiver should work no problem after this but you will pick up a lot of german tv on 19 east. ![]() ralph | ||
| The Following User Says Thank You to ralphmagno For This Useful Post: | KyleRickards (29-09-2009) |
| | #8 | |||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | ![]() But you know what to do now if you do fancy looking at Astra 1 @ 19.2E sometime in the future... | |||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | ||||
| The Following User Says Thank You to 2cvbloke For This Useful Post: | KyleRickards (29-09-2009) |
| | #10 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | I found one of those lnb's in my junk box. Its a Cambridge AE35 9750MHz enhanced type. Will work for satellite frequencies up to about 11700MHz or for all the 19E analogue channels. (Also found several universal lnb's Id forgotten about | ||
| | #11 | ||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | | ||
| analogue, dish, fortec, sky |
