motor connectionsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
| Member Join Date: 01-10-2009 Location: Malta
My System: Satelitte newbie found a 1.8m motorised dish installed with new flat. Computer literate Win Vista broadband etc. | Can I put on your good natures with a final stupid question in the thread? The Echolink 7020HD manual is not very clear unless you are an experienced user! Where I had the choice of using the books section on DiSEqc 1.2 or Positioner - I chose DiSEqc 1.2 but should I be using Positioner. The book talks about a position adapter????? I have a Technomate V-Box 3 is that the same as an adapter. There doesnt seem to be any difference in practice. I tried both & the motor selects the sats correctly in either case. Thanks for looking. | ||
| connections, motor |
