motor connections
Old 01-10-2009   #1
My System: Satelitte newbie found a 1.8m motorised dish installed with new flat. Computer literate Win Vista broadband etc.
motor connections
Hello, new to forum and hoping you will get me started by answering a basic question as I know absolutely nothing about motorised dishes and am keen to get into it.
(Ex Marconi & RAF RADAR eng so OK with radio theory etc but newcomer to this subject)
I have moved into a flat (Malta) & it has a dish about 1.8m on the roof.
it is presently pointing at Hotbird and receives OK. My problem - it is a motorised dish connected up at the dish end but in the flat next to the incoming sat coax is the power cable which looks like telephone cable, it has 4 cores, Orange, Blue, White and White orange.
Could someone please explain what they do (voltage etc) and how are they connected ie do they connect to the rear of a suitable receiver or some sort of mover box? Dont know what to buy as yet.
Thanks for looking.
rover3 is offline   Reply With Quote
Old 01-10-2009   #2
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
Welcome to the forum!
Motors run on 36v, the polarity governing the direction. The other 2 wires are for the reed switch which sends pulses as the dish moves so the positioner knows where it is. You'd probably want to check at the dish to see what colour code has been used (or you could maybe deduce it by measuring resistances).
pgh13 is offline   Reply With Quote
Old 01-10-2009   #3
Modern receivers commonly use Disecq for satellite selection which is a system for signalling through the co-ax. You can get something called a V-box to convert your 4 wire dish motor to disecq control
Old 01-10-2009   #4
satelliteman's Avatar
Real name: Paul
Yes, best to check and find the corresponding ends of the cables. Connecting to the wrong terminals on a positioner will result in damage.
satelliteman.
An Installers Choice
Follow us on
Old 01-10-2009   #5
Thanks for replies. 78 ohms between Orange & Blue, open cct everywhere else.
Old 01-10-2009   #6
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Sounds too high for a motor cable. Normally around 15-25 ohms. How thick are the wires with that resistance reading? Something like a 5A mains cable?
Llew is offline   Reply With Quote
Old 01-10-2009   #7
Wires are look just like those in an old BT telephone wallsocket not the diameter of 5A
Old 01-10-2009   #8
ps so if its 70ohms and if its 36v mine would be about 0.5A whereas what you suggest would be 1.5A say?????????
Old 01-10-2009   #9
Llew's Avatar
Probably what it is then. Sure the White's not White/Blue?
Old 01-10-2009   #10
Llew's Avatar
1.5A at motor startup (starting torque) with 36V into my suggested ohms value for an actuator +wire resistance.
A BT style telephone cable should never be used to run a dish motor. If that's worked before, I'll be surprised.
Old 02-10-2009   #11
You are right of course - White / Blue
Old 05-10-2009   #12
Thanks all for the help
Old 15-10-2009   #13
Have some progress, can select sats and move onto them by operating the V-Box remote but cant drive it from the receiver, sorry I know it is a stupid question- the choices on the receiver menu are
DISEqc 1.0/1.1
DISEqc Sw Disable/Mode 1 2/4 etc
Positioner None/DISEqc 1.2 /USALS
Can you give me a start please?
Old 15-10-2009   #14
Sorry forget the stupid question the penny dropped at last.
Old 17-10-2009   #15
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
did you select diseqc 1.2 and then search and store the positions as thats all you need to do
Old 17-10-2009   #16
Yes thanks now have dish driven by receiver all labelled up.
My next problem is very very basic and have done alot of forum searching but just have to ask. Presently I have set everything up using a very basic 50 euro FTA Liddl's receiver and am now considering a Echolink which has 2 CI slots and a cam I think.
Is there a definitive list of what cards do what ie are they linked to specific satelittes. eg say I wanted to look into Hotbird 13 where do I find out what to order.
Do receivers come with cams or do you have to buy a cam first then a card.
Any basic help appreciated and I will keep studying the forum / rules while hopefully making some progress to learn the subject.
Thanks for looking.
Old 17-10-2009   #17
wod
wod's Avatar
what cards are you looking at getting ?
for example aljazeera sport on hotbird use viacess so will require a viacess cam or receiver which is compatible with that encryption
a receiver like a technomate will read a lot of the official cards without the use of a cam
Old 17-10-2009   #18
Mod and septic resident
Channel Hopper's Avatar
Which particular Echolink might you have, or are getting ?
Embedded CAM versions on their own are basically a FTA bx these days.
Software for ECHOLINK
Old 18-10-2009   #19
Thinking about Echolink EL-7020 no point getting another basic receiver I would only want to change it in a couple of weeks, open to advice though possibly Technomate? Would like an HDMI output but perhaps most receivers have that anyway. Otherwise the most convenient & useful box for cards etc. Ill pick up the rest as I go along.
Thanks for looking.
Old 18-10-2009   #20
My System: Humax, motor, 80 cm dish
1. Go to en.kingofsat.net and you will find detailed info on satellites. programs encodings and cams to decide what subscription you need.
2. Your "very basic 50 euro FTA Liddl's receiver" (e.g. SL55 or 65) may be tuned up to surprising performance. Visit the appropriate forums.
(You seem to know which end of the soldering iron is hot, so making a nullmodem cable must not be a problem.)
caracash is offline   Reply With Quote
Old 18-10-2009   #21
Many Thanks
Old 3 Weeks Ago   #22
Back again with another silly question if someone will please oblige.
Eventually got the Vbox driving from the receiver (Echolink 7020) and saved some sat positions in the receiver menu having scanned channels in. Now the system often changes to a different satellite without me asking it to, is this usual? Could it be when it is near to the setting of another satellite position with stronger signals.
Do I need to save the same position on the V-Box itself?.
(Had no problems with my old chepo Silverline FTA which also seemed to have far better sensitivity and found more signals).
What am I doing wrong?
Technomate V-Box 3
Echolink 7020HD
Satellites presently stored Astra 28.2, 23.5, 19.2 plus Eurobird 1 28.5 and Badr/Eurobird 2.
ps I am in Malta so anything can happen plus I am still stabbing in the dark.
Old 3 Weeks Ago   #23
Check your channel list. Channels of the same satellite should be grouped. If you use an ordering of some kind (Favorite Channels, alphabetic order etc.) channels of different satellites might get mixed up in the Ch list. Stepping through the list may make the drive move to and fro.
(Possible but not very likely explanation)
Old 3 Weeks Ago   #24
Afterthoughts.
"...my old chepo Silverline FTA .... seemed to have far better sensitivity ..."
It's funny: I have the same experience with my very old Comag and my new Echosmart
Looking at the coverage map you seem to be rather far out of reach for Intelsat 10-02 DigiTV xmissions. But it would be a very interesting experiment to turn your dish to 1°W and set up your chepo FTA box to the following FTA channels:
Intelsat 10-02 (1°W)
DigiTV Info 12608.00 H - 27500 3/4
U (Romania) 12643.00 H - 27500 3/4
DDTV 12643.00 H - 27500 3/4
Old 3 Weeks Ago   #25
Thanks for that you may be onto something there as I have noticed it when going quickly through channels and on the satellites I have there are a number of channels which are the same but on different sats. eg QVC etc .
Will try for Intelsat 1 W when I can get the TV off her indoors again.
connections, motor
[IMG] code is Off
