Can anyone identify the angle of dishes?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 03-10-2009 Location: North west, UK
My System: Mac mini (intel) 2.0 Ghz EyeTV Sat EyeTV v3.2 |
Hi, I just bought a receiver (EyeTV Sat) and am trying to work it out. At this moment, I cannot see BBC and ITV's main channels. My flat has 2 dishes installed already when I moved in and I am expecting that one of the dishes can be used with my receiver. According to web search, all I need to have is a dish which faces to 28.2 E for Astra 2D to receive BBC/ITV. The 2 dishes are facing at different angles. So I was hoping one of them are facing to 28.2E. However, when I auto-tune with both dishes, there is no BBC(main channels)/ITV in the list of found channels, even if the total number of the tuned channels were more than 200~300. Providers of channels from Dish 1 (not name of channel) Eutelsat, Telespazio, CYFRA+, DMT, OVERON, GlobalCast...etc BBC radio channels were tuned but no BBC TV. Providers of channels from Dish 2 Digital+, ARD, TVP, IMEDIA, ZDFvision...etc (Note: these auto-tune was done with 28.2 Astra 2D settings, when I change the settings to i.e. 19.2, 28.5, 26.0....etc, I could tune BBC world) I checked which satellite is broadcasting these channels on websites, that looked to me that I'm receiving 19.2E (Astra 1x), 28.5E Eurobird1, 13.0E hotbird but no 28.2E. I think I anyway have to try re-align the dishes but I'm wondering why I cannot receive 28.2E. At least 19.2, 28.2 and 28.5 are very close each other and I think my receiver/dishes should be able to receive 28.2, as it receives channels from 19.2 and 28.5. If anyone can advise me for my situation to receive BBC/ITV, it will be appreciated. ucq | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, Most probably you are receiving from 19.2E Astra and Hotbird 13E. You cannot be receiving from Eurobird 1 as well as you only have two dishes. What do you want to do? Re-align one of them for 28.2? The 19.2E will be your easiest option: swivel it eastward by about 9 degrees and lower the elevation a tad. Do it while monitoring a transponder on 28E. | ||
My System: Mac mini (intel) 2.0 Ghz EyeTV Sat EyeTV v3.2 | Thanks for your quick reply. Yes, I'm going to re-align one of them. One (maybe stupid) question, can one dish not receive 2 satellites? If not, why my receiver could tune channels from wrong satellite (19.2E) when i tried to tune for 28.2E? Thanks. | ||
| | #4 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| On the hand I can't receive Nilesat on 7W (3 degrees difference). When you try scanning, the receiver will catch the channels that it can receive, regardless of which satellite you tell it to catch. For example, as I have only Hot Bird 13E, if I try to scan Astra 19.2E, the receiver will bring me only transponders that it can see from Hot Bird 13E. | |||
| Last edited by HB13DISH; 04-10-2009 at 08:39 AM. Reason: Stressing using one LNB | ||||
| | #5 | ||
| Specialist Contributor Join Date: 12-01-2005 Location: naples italy
hello, one dish can receive more that 2 satellits. example i have set up one dish picking up 3 satellits. one 19 est one feed 16 east and one 13 east. all 3 are 3 degrees apart. uning a 3 input disec switch will do it . each satellite will loose a little signal, except the one in the center. i have seen toridal dishes that would pick up 4 or 5 satellits that were close together. and i have seen dishes were the lnb would move on a sliding track with a small motor as well. i don't think the sky box will support disec signals. if you align onr for 13 east and another for 28 east and use a free to air receiver and disec switch there shoud not be a probleme if you know how to set this up. hope this helps ![]() ralph | ||
| | #6 | ||
| | #7 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #8 | |||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | The reason the box needs to know the orbital position of the satellite is so it can select the correct aerial system for that satellite. If your aerial system is only capable of receiving from one orbital position and you do a scan for the channels on another position you are just rescanning the same satellite. | |||
| angle, dishes, identify |
