Offset 90cm and what next ??Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Real name: Martin Join Date: 22-11-2007 Location: Norway
My System: Relook 200S Relook 400S Pace DS810XE IPBox9000HD Triax 90cm motorised Offset 90cm polarmount |
Hi I just get Philips offset dish 90cm polarmount full package with Philips positioner and Philips feedhorn. I want to use it as a replacment of my 90cm TRIAX with motor (motor gone). Have few question about this package. 1. My positioner does not have connection to LNB to translate 36V to DiseqC just 5 wires to connect motor. Does VBox2 will do the job? (have IPBOX9000HD) if not what is the solution? 2.Is there any HD box which can work with this dish without positioner. I mean with vbox or something bildin ? 3. If I want to instal LNB with 4 outs which one will you recomend? 4. Does the offset dish will have better signal quality that my old dish? Thank for help | ||
| Member Join Date: 06-07-2008 Location: Devon
My System: Echostar AD3000Ip Viaccess, Fibo 90cm Motorised Dish, Invacom C120 LNB, T/Rex. | Sounds like you may have a Fibo (Philips) 90cm, offst dish - like mine. If so, did it come with the 36v motor? Most modern receivers have Diseq control and you may need a V Box to enable control. Not sure about this myself as I have always had a receiver with 36v motor control. At present I am using a Topfield TF5000CIP which works well with my dish set up. Hope this helps. Dave | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The Gloabl Invacom QDF-031 quad universal works very well on the Fibo gregorians. Also, it doesn't suffer the disadvantage that the Inverto C120s have, you can't get zero skew on them, as the LNB hits the LNB arm. Yes, the dish will outperform the 90cm Triax. More info needed on your motor, by positioner? do you mean motor. The standard Fibo one is 36V with an optical sensor used to track the position. The optical sensor requires a 5V power supply, which your V-box will need to supply. | ||
| The Inverto can be used 'inverto' on the Fibo dish, as long as the cables are tied closely to the bodywork, there is no 'shadow' on the reflector surfaces. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #5 | ||
My System: Relook 200S Relook 400S Pace DS810XE IPBox9000HD Triax 90cm motorised Offset 90cm polarmount | Hi Thank for help. Motor I mean that small box connected to move dish. Positioner in my opinion is that box which you have to connect to the motor to give power or move it by pressing buttons on the remote control. The point is that my positioner does not have in/out for LNB, just for motor or sensor. I think package I have got is old and was designed for analog sat without diseqc control. | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Ah, right, surely though if you get a V-box you don't need the positioner then, just connect a V-box with the approriate capabilities to the motor. Just make sure you get one with the 5V o/p to power the optical sensor. The 36V power lines are the same as any other 36V motor. Ya mean upside down CH? | ||
| | #7 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed |
| | #8 | ||
| Folding*home Join Date: 23-02-2006 Location: Madeira
My System: [ Relook 250S ] | You need a v-box2 it has the 5v connection, but you need one compatible with your ipbox9000 to be able to use the motor via diseqc. There are complaints about some vbox not working well with that receiver, it's a programing diseqc bug with the receiver i have no idea if it was fixed. I think, not sure, it was the motek vbox that had issues with that receivers diseqc. Search the forum on this subject, there are other brands around that should work. I hope that bug got fixed, i haven't been around much lately so this could be wrong now. Best of luck. | ||
![]() When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork." | |||
| | #9 | ||
My System: Relook 200S Relook 400S Pace DS810XE IPBox9000HD Triax 90cm motorised Offset 90cm polarmount | Thanks all for help. Now I have to find VBox and instal dish. I will report the results. THX | ||
| | #10 | ||
My System: Relook 200S Relook 400S Pace DS810XE IPBox9000HD Triax 90cm motorised Offset 90cm polarmount | Hi Does anyone knows how to reset Philips 36V positioner box. Have stupid readings. On east it goes up to 479 which is around 50 degrees (scale is 60 both sides) to west it goes up to 0 and this is around 25 degrees on the scale. I does not want to move more. Can I find manuals for this old box? Have no name or model number, number from remote control shows page with remotes. Anyone have such a box? Thanks for help. | ||
| 90cm, offset |
