help; no signal
Old 05-10-2009   #1
My System: i bought it in lidl ireland, its a digital satellite system with reciever SL65, antenna CO80 and universal twin LNB
help; no signal
i purched and instaled a new digital sat system with reciever SL65 and antenna CO80 universal twin LNB. i have tried most things to solve the problem ,has anyone an idea how? the menu comes up on tv ok, but says NO SIGNAL. i went to astra 22.8 sat and scan for that and it still says no signal, i tried TP scan and it comes up with signal intensity of 83% and signal quality 14%. i have no signal for tv or radio channels and i tried scanning for all stalites in turn., i bought it in lidl. i live in galway ireland and local tv agents wont touch only their own dishs.
enquireing is offline   Reply With Quote
Old 05-10-2009   #2
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
The Satellite you want is 28.2, not 22.8, but your problem is most certainly failing to align the Dish correctly.
When you get close to the correct position, you'll see the quiescent Strength and Quality readings you've got (which indicate little more than that you've got an LNB connected) swing sharply upwards.
You need to be accurate to within a degree or so, not just in direction but also in elevation.
Tivù is offline   Reply With Quote
Old 05-10-2009   #3
i did swing the dish upwards from 1 degree to 45 degrees up and then the signal intensity off 83% went to zero% while the signal quality remained at 14%. i even attached the dish to a mobile pole today, and had a guy stand at different posisions around the south east side of house and in each posision we scanned and no signal still. i do relise it is a posision problem,
Old 05-10-2009   #4
Amo Amas Amant Admin
Topper's Avatar
Well
You have to be millimeter perfect, it is not like the analogue days, each time you make an adjustment you need to wait 20 seconds for the equipment to process the signal. In general you dish will be approximately horizontal in appearance from the side as per pic below
There are tutorials on the forum
http://www.satellites.co.uk/satellit...rised-systems/
scroll down to the stickies
help; no signal-dish-jpg
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 05-10-2009   #5
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards
just to add to the excellent advice you've already received..
This sounds like a job for :-
_http://www.dishpointer.com/
enter your street location and select the satellite you are after..
You'll get a line pointing the exact direction you need to be aiming ...and dishpointer will also provide the elevation setting for your dish at your location.
rgds
VS
Vipersan is offline   Reply With Quote
Old 05-10-2009   #6
tks topper, i have not put it to horizontal posision ,but shall try that next. worse than i am at present i cant be. ,tks again
Old 05-10-2009   #7
rgds
VS
oops sorry' bout the brief live link boss ..
thanks for sorting it quickly m8.
Just my haste to reply
rgds
VS
signal
[IMG] code is Off
