Diseqc 1.2 and 2.0 Set up help
Old 05-10-2009   #1
My System: Topfield 3000CIpro fta Dell Inspiron 5160 laptop
Hello,
I have a Topfield 3000 CIp receiver which is equipped for Diseqc 1.2, but the 4-way switch at the dish is 2.0 according to the label on it.
My question is: are they compatable?
I cannot get the receiver to receive from Astra 2 and Astra 1 at the same time - yet I can get both individually i.e. after I disconnect one of the lnb cables from the switch and leave the other connected.
Another problem is that the receiver doesn't seem to know which satellite it's pointing at: e.g. if I try to scan Astra 1 it will scan Astra 2 again, and I got 19.2 under Arabsat label.
Thanks.
shortlegs is offline   Reply With Quote
Old 06-10-2009   #2
satelliteman's Avatar
Real name: Paul
Moved your post to dish set up section.
Sounds like you haven't configured the receiver for DiSEqC switching correctly. Compatibility shouldn't be a problem. In addition, take a look at this, might be of some interest _http://en.wikipedia.org/wiki/DiSEqC
satelliteman.
An Installers Choice
Follow us on
Old 06-10-2009   #3
Robbo's Avatar
Real name: Mark
Diseqc 1.2 is not compatible with Diseqc 2.0 as per the wiki article. Diseqc 1.2 is for motors.
You need to use Diseqc 1.0, which is the one way communication version of diseqc 2.0
Old 06-10-2009   #4
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
Robbo the motor should just loop the commands through to the switch, it shouldn't matter what diseqc level the motor is. And even if the receiver is only diseqc 1.x and the switch is 2.x it will still work fine it's just that the receiver ignores the confirmation signal.
Topfield 3000 is diseqc 1.x so the motor is definitely not going to have trouble looping these commands through to the switch.
Huevos is offline   Reply With Quote
Old 06-10-2009   #5
My System: c and ku band setups
My problem is also the same i live in india
Iam having 2 ku band dishes and recieveing 2 satellites
I deleted every thing and installed a fresh i installed new satellite by name Insat in satellite options with port 1 and tuned the channels all the channels came.ie 1 to 64
Now what i did in the same Insat i changed to port 2 and recieved all the channels of asiasat ie 65 to 85 .
But the thing is when i i want to watch insat i have to change to port 1 in the satellite options and to watch asiasat i have to switch it to port 2.
I can see cant receive the channels simultaneously. though i can see the list.
Previously i made 2 satellites in options ie insat and asiasat with respective ports.
when i autoscan satellite channels were coming but while saving it is replacing
previously saved channels.For ex i scanned channels of insat channels are coming and stored.
next when i scanned Asiasat channels are coming but while saving its replacing
insat channels.vise verse i tried a lot but no posotive results.
2 days back while experimenting i was able to watch channels from both the satellite simultaneously but didnt came to conclusion exactly how it came
so to know the exactly how it came i deleted everything and started again but didn't succeed.
My receiver is disq 1.0 support and switch is 2.0
Please help
in_msz is offline   Reply With Quote
Old 06-10-2009   #6
Robbo's Avatar
Real name: Mark
Yep, I know, I have done it, but you still can't control a diseqc1.0 switch with diseqc 1.2 commands, which was what the OP was asking was possible.
Old 06-10-2009   #7
I think it's the way the question is worded. Nevertheless the Topfield 3000 supports both diseqc 1.0 and 1.2 so my guess it's a configuration problem just as Satelliteman says.
Old 06-10-2009   #8
Real name: Ravindran
My System: Insat 2 E Telstar 10 Pentium 4
I need to connect a DiSEqC switch. Can anyone advise on the configuration parametres that one ned to enter with the remote controll of the digital receiver ?
ravindranchennai is offline   Reply With Quote
Old 06-10-2009   #9
Robbo's Avatar
Real name: Mark
Quite tricky that one, with the information (or severe lack of it) that you have provided.
Old 07-10-2009   #10
Thanks for that.
Robbo I think what you're saying is that I should specify a 1.0 switch for use with this tp receiver.
diseqc
[IMG] code is Off
