Freesat set up helpInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 06-10-2009 Location: Cheshire, UK
My System: Have Sky+ but am trying to gen up on the hows and why's of fitting a motorised dish |
Hi there everyone.... i'm a very green newbie to all this..... I've just bought my step daughter a satellite free view dish and set top box etc The only problem i've got is that i don't know which satellite i'm supposed to align the dish to...... I have a signal tuner thingy but it's useless without knowing WHERE i'm supposed to point it..... Any and All help and advice would be most gratefully recieved... Johnni12 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | You need to align the dish to the Astra 2 cluster at 28E ![]() BTW - you have bought a Freesat or Free to Air receiver - Freeview is the terrestrial system carried through the transmitter network | ||
| Specialist Contributor Join Date: 29-06-2009 Location: UK
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards | Hi Johnni.. You need to be pointing at Astra 28.2 deg East You can get a good idea of the direction from your location by entering your location details and the satellite you require at _www.dishpointer.com It will also provide elevation details for your location .. rgds VS | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Welcome to the forum, Changed title of this thread to one more appropriate. For 'freesat' you require the 28e slot. This will be approx 144° from your location. More info available at _http://www.dishpointer.com/ Use a compass for a rough bearing, connect up the meter, align the dish and once you have a signal scan the receiver to see. Edit: too slow again. | ||
| freesat, set |
