EMP Centauri P 168-W V2 & DREAMBOXInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 07-05-2009 Location: Italy
My System: Ipbox 350 |
I purchased the disecq EMP Centauri 8x1 P 168-W V2 but I can not configure it for the Dreambox. I connected the lnb as follows: IN 1 ---- Motor Stab IN 2 ---- Hotbird IN 3 ---- Astra IN 4 ---- Hispasat IN 5 ---- Turkisat I followed the directions on the DEC proposed by various users on various topics including the forum. The result is that the engine is working but still no signal on the parables. Someone who uses the same disecq dreambox and connecting motor and more parables fixed can you please post your configuration? | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | | ||
My System: Ipbox 350 | tried this configuration: LNB0- Motor Toneburst= Niente-Mod.Diseqc=1.2-Param.Diseqc=A/A-Ripet.Diseqc=Niente-Uncommited Swicth=Entrata 1, no selection 6/7/8. Swicth Centauri 8X1 collegamento a IMPUT 1. LNB1-Hotbird Toneburst=niente-Mod.Diseqc=1.1-Param.Diseqc=A/B-Ripet.Diseqc=2-Uncommited Swicth=Entrata 1 - 6/7/8 no selection Swicth Centauri 8X1 collegamento a Imput 2. LNB2- Astra Toneburst=niente-Mod.Diseqc=1.1-Param.Diseqc=B/A-Ripet.Diseqc=2-Uncommited Swicth=Entrata 1 - 6/7/8 no selection. Swicth Centauri 8X1 collegamento a Imput 3. LNB3-Hispasat Toneburst=niente-Mod.Diseqc=1.1-Param.Diseqc=B/B-Ripet.Diseqc=2-Uncommited Swicth=Entrata 1 6/7/8 no selection. Swicth Centauri 8X1 collegamento a Imput 4. LNB4-Turkisat Toneburst=niente-Mod.Diseqc=1.1-Param.Diseqc=A/A-Ripet.Diseqc=2-Uncommited Swicth=Entrata 2 6/7/8 no selection. Swicth Centauri 8X1 collegamento a Imput 5. The motor works, but I have not fixed the signal | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | To start with disconnect the motor and ignore it for now. See if you can get the fixed dishes working. | ||
| | #5 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Diseqc 1.0 switches don't always work with motors. Yet you have used Diseqc1.0 to switch between the motor and three of the other LNBs. Might be worth a try using the uncommitted (diseqc1.1) for switching between motorised and fixed. i.e uncommitted 2 ->motor uncomitted 1 -> Fixed LNBS via Diseqc 1.0 (AA AB BA BB) | ||
| | #6 | ||
My System: Ipbox 350 | ok...work. Solution: Motor LNB0 Diseqc 1.2 A/A Uncommited Entrata 1 Hotbird LNB1 Diseqc 1.1 A/B Uncommited Entrata 2 Astra LNB2 Diseqc 1.1 B/A Uncommited Entrata 3 Hispasat LNB3 Diseqc 1.1 B/B Uncommited Entrata 4 Turkisat LNB4 Diseqc 1.1 A/A Uncommited Entrata 5 Thank's | ||
| 168w, centauri, dreambox, emp |
