New system. Where to site the DishInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 08-10-2009 Location: Leicestershire, UK
My System: No sat set up yet !!!! |
Afternoon all Newbie here looking at installing my own system at home with either a 80cm mesh dish or a penta 68. We tend to get quite high winds due to living on a bit of a hill so have a few concerns on dish placement and also the reason for considering a mesh dish.The wind tends to blow down the side of the side of the house. Just wondering if some of you experts could have a look at the picture below and advise. The back wall is virtually square on to 28.2E. and there are no line of sight problems until about 5.0W where the nieghbours house may obstruct as they are about 1.5 meters higher than ours. Thanks mercuryman | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Welcome, Assume your referring to a motorised system. Can you upload a picture of the rear view by any chance. | ||
| Specialist Contributor Join Date: 29-06-2009 Location: UK
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards | Hi m8 Assuming we are seeing a picture of the front of your house and assuming you want a motorised system..then mounting on the wall to the rear of the property will give very restricted access to the western half of the satellite arc .. You would get some improvement in western visibility if you lift the dish above gutter height ..but this exposes the dish in high wind conditions .. If you have garden to the rear ...you night consider pole mounting at the bottom of your garden ? rgds VS | ||
My System: No sat set up yet !!!! | Apologies, I didn't explain very well. Yes it is a motorised system I was looking at, and the attached picture is a view of the rear of the house from the garden. The garden isn't a great size so i think a floor/garden mounted dish is out. | ||
| | #5 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | You say the 'back wall is virtually square on to 28E'. It's always a little easier with photos showing a sky dish to compare but I guess either a garden fixing or T&K wall mounting to raise the dish above gutter height. | ||
| dish, site |
