Two Dishes one reciver How to connectInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 21-09-2006 Location: North East UK
My System: Motorised dish with twin LNB, fixed dish with quad LNB Dreambox 800HD and TM9100 receivers Pentium 4 |
Please let me say what a fine forum this is and I am hoping for some good help for a newbie. First off what I am trying to acheive is to be able to operate two satellites through on receiver. My setup is as follows. A 1m movable dish and a zone 2 S*y dish pointing at 28 east, my receiver is a DM800HD. I have tried placing a 2x1 disqec switch between the reciver and motor but the motor would not move on command with this setup also I have placed the switch between the motor and LNB and again not switching. Are the switches bad? or is my setup wrong was thinking of getting a Spaun switch to see if that would help. Thanks in advance for helping a newbie. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Put the Diseqc Switch between the motor and the LNB, with the B port for the minidish. There are a couple of threads describing this from a while back. Then for all satellites apart from Astra 28,2, allocate motorised, but for Astra 28.2, allocate port B DiSEqC. | ||
Hi Rolfw thanks for your quick reply, sorry if I seem dum but what settings should I use on my receiver which is a DM800. At the moment I believe the installer set it at positioner, are you saying I should alter this to something else has I believe he said the motor would not move if set to anything else or is he giving me some duff info. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You need top take Astra 28.2 out of the positioner list and set it to DiSEqC 1.0, port B. Unfortunately I no longer have a Dreambox connected, so can't help with the exact settings. | ||
| connect, dishes, reciver |
