Need advice, installing motorised systemInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Real name: 1madjock Join Date: 12-10-2009 Location: wales
My System: channel master 90cm dishand echostar ad3000ip reci ever |
hi there,just new to the site i am installing my motorised system tomorrow morning (wed 14th oct)i have a channel master dish and an echostar ad-3000ip reciever been busy collecting info as to where i am regarding long and latt figures i live south wales in canton so information i have is( long -3.215/latt 51.485/elevation 31deg/lnb skew for thor sat -1.9 wish me luck)if this sounds ok please post reply dont want to be up a ladder all week got the pub to go to many thanks madjock | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You can double check your latitude and longitude on multimap or similar, Skew should be zero on a motorised dish . You will also have to allow for being 2 degrees West of Thor 1W when lining everything up. Have moved your post from the installer section, as I presume this is a DIY job. | ||
| The Following User Says Thank You to rolfw For This Useful Post: | 1madjock (14-10-2009) |
My System: channel master 90cm dishand echostar ad3000ip reci ever | thanks for such a quick reply,i have put my postcode into dishpointer .com and thats the result that came up.so out of interest why is there no skew needed on my lnb motorised dish cheers | ||
My System: channel master 90cm dishand echostar ad3000ip reci ever | i have been on multimap.com put in my postcode cf5 1## and still comes back with the same long and latt figures no harm in double checking everything as this will hopefully save time later | ||
| | #6 | ||
My System: channel master 90cm dishand echostar ad3000ip reci ever | when you say send do you mean manually move it because i wasnt wanting to move it with motor as i have every thing centered and in line i was waiting until i found thor as it is then tighten every thing up then start to go round the arc to see if i could pick up more sats if not bring it back to thor loosen again and tweak it some more but thats my way of thinking ,does that make sense or is there an eaiser way | ||
| | #7 | ||
My System: channel master 90cm dishand echostar ad3000ip reci ever | be back later on call of to bristol check posts when i return am on until six in the morning anyway cheer speak later | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | As 1W is not your Due South, you need to drive the dish two degrees East of centre, then align on 1W, this should give you the top of the arc. I'm assuming that you have a polarmount, and the reason that you don't require any skew on the LNB, is that the mount will tilt the whole dish as it moves around the arc. | ||
| | #9 | ||
My System: channel master 90cm dishand echostar ad3000ip reci ever | i understand now ,i was told when you go round to say 30 east or west the whole dish looks twisted and points more lower and of course the lnb is attatched and moves and dips with the dish, sounds easy once you know that the sats get lower the more you move round the arc.i wish i had thought of that.cheers again,i will let you know how i get on in the morning. | ||
| | #10 | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Similarly, it effectively adjusts the Elevation. That's how the Motor or Actuator works - by tracking the Clarke Belt. Obviously it can only do so correctly after you've set the system up mechanically in accordance with your Latitude. Edit: Drat. Didn't read far enough down the Thread: rolfw has already responded. I blame my Head Cold - back to bed. | |||
| | #11 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Also having a longitude of 3.2151°W, you could move the polar mount 1.8° West of centre for alignment onto AB3, another strong satellite on which you could set up on. Either way both are as close as each other, but another option | ||
| | #12 | ||
My System: channel master 90cm dishand echostar ad3000ip reci ever | thanks for the tips lads but to no avail,if i was up that ladder once i was up there 100 times,i have a good view of the south ,set my dish up found about six sats but could i find thor,not for love or money could i find it,could someone please check to see if it is still there as i think it must have fallen out the sky overnight anyway am going for a bath and then for a pint,tomorrow is another day please e-mail some info for installers canton cardiff area cf5 thanks | ||
| | #13 | ||
| Regular Member Join Date: 04-09-2006 Location: Kent, UK
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | As two members have suggested, look for 5w instead. You can use either transponder 11591H 20000 or 12543 H 27500. You should get this readily and then try to get the signal quality to the highest you can; if you do this, then 1w ("Thor") should come in by itself more or less. EDIT: I realise now that this is a Polar mount rather than diseqc motor so have deleted reference to USALS. | ||
| | #14 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Think O/P is using 36v although this hasn't been confirmed as of yet. | ||
| | #15 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | If the OP is using the Echostar for driving the dish, it has to be a 36V motor/actuator. The AD3000IP doesn't do Disecq 1.2. | ||
| | #16 | |||
| Member Join Date: 09-04-2009 Location: Buckinghamshire(H.Wyc)
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E | That's how the Motor or Actuator works - by tracking the Clarke Belt. Obviously it can only do so correctly after you've set the system up mechanically in accordance with your Latitude. just to clarify on locus basically the same way u draw a circle using a compass? the motor being the centre and the lnb being the circumference as it goes along the arc??i am rusty in maths just refreshing | |||
| Last edited by satelliteman; 4 Weeks Ago at 02:48 PM. Reason: Repaired [quote] code | ||||
| advice, installing, motorised |
