LNB Protection
Old 17-10-2009   #1
smiffie's Avatar
My System: Dreambox 800 HD 500Gb, Dreambox 500 S, VBox 2, Jaeger 99G H to H 36v, Invacom Twin LNB 0.3db, 85 cm Mesh Dish
LNB Protection
I have an Invacom LNB which is now getting on, but its a great bit of kit. The problem is that I've noticed that the window which protects the feedhorn has a a big hole in it; probably due to ageing, the unit still works fine. Can this be replaced? It looks like the actual housing is moulded plastic, can this be removed? I have an old faultly LNB and was thinking of pitched the cap and somehow fitting it to this unit.
smiffie is offline   Reply With Quote
Old 17-10-2009   #2
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards
Hi Smiffie ..
So long as the material chosen to cover the feed is transparent to the incoming signal it should be ok ..
A cover grafted from another LNB should do the job just fine...
rgds
VS
Vipersan is offline   Reply With Quote
Old 17-10-2009   #3
satelliteman's Avatar
Real name: Paul
Might be worth checking for signs of any water ingress, if so then a replacement required.
satelliteman.
An Installers Choice
Follow us on
Old 2 Weeks Ago   #4
smiffie's Avatar
In the end it was a pretty straight forward job, the weather proof cover simply clipped off and the I used a craft knife to cut the remaining bits of the plastic window off the feed horn flange.
The only damage I could see was where peices of the window had flaked off and dropped down the horn, which I shook out.
I then marked up a thin sheet of plastic using the flange as a template, cut a disk out of the sheet and glued it onto the flange using araldite rapid. Re-clipped the weather proof case over the top and re assembed, ready for the winter.
lnb, protection
[IMG] code is Off
