help neededInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 18-07-2009 Location: orebro,sweden
My System: hotbird ,astra |
hi am in orebro,sweden i have 2 dishes . ist is 1.2 meter with 3 lnbs for hotbird,astra19 and astra 28. i took this new dish for astra28 and arabsat ,first installer said that with this i can get astra28 and arabsat perfect but when he installed it i only got mbc from arabsat and astra was not working fine aswell and he was just saying different things that its only 2 degree difference and both cant work and i asked to tak out arabsat lnb and give me fine astra 28, he did but still its not fine am not getting like bbc ,sonytv,satmax,zeetv, cnn ,itv,cartoonnetwork,disney etc. so for first thing that can i get rotana package from arabsat and perfect astra 28 from this my new bought 1.2 meter dish with wich i have lnb for hotbird which is 85 persent ok and astra is 95 persent ok. so can i get my rotana and perfect astra or not or just can i get astra 28 perfect so please let me know,this was first thing . second is that i have another 90 cm trix oval shape dish which i installed to sirus 4.8 and question is that can i get .8 thore, intelsat 7,and 9 east sat with this ext satup dish please guide me for this. third thig is that i have 2 diseq switches 4 port each if i have installed 7 lnbs and i dont have 8 port diseq switch can 2 diseq switches 4 port each can it work if so how and i have db 500s. thank you very much. looking forward for response. regardz shaz | ||
| Member Join Date: 02-07-2005 Location: Essex
My System: 80 x 90cm mesh+DarkGold 0.1Lnb 53 east to 45 west, TM5200D usb super<<A/B>> TM6800HD+, 90 x 100cm Gibertini+MTI 0.3 Lnb>> 45 east to 58 west, TM6900HD Combo Super+<<A/B>>TM1500CI+ Super>>Quali 4:2:2 receiver. | Not much hope of getting Rotana package as this is on the very tight footprint on Badr-6 | ||
| Specialist Contributor Join Date: 29-06-2009 Location: UK
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards | Hi friend .. I've just looked at the footprints for various beams on Astra 28.2 If it is the Freesat channels you are trying to receive ..these are located on Astra 2D ..and use a spot beam centred directly over the UK .. ..This beam falls well short of your location ...though many beams from this orbital spot do illuminate Sweden .. Go to lyngsat ..and check which channels you want to receive ..then open the corresponding footprint map (extreme right of the transponder info) to see if it is possible for you.. ..you should for example ..be able to receive the BBC News transponder on the 2B South Beam 11954 H tp 13 rgds VS | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| needed |
