receiver & satellite help?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 29-08-2006 Location: us
My System: i enjoy using computer |
After Greetings There is a dish installed in it (nilesat) with two outputs for two places. In the next side two receivers with the same name (Hivion 9090fta) for both places. Now the problem is: (when you switch on one receiver (only one of both) , most of channels can't open untill switching on the next receiver) which it mean I can't watch all channels if one of the two receivers switch off How can I solve this problem? Best Regards Ahmed Hassan | ||
| Specialist Contributor Join Date: 12-01-2005 Location: naples italy
hello i saw this. are you sure the lnb in new and has 2 outputs? or did the tech use a single output and and split the signal? if the installer used a single and split the signal it will not work. if the lnb is old it may be difective. take the boxes and swap them put box 1 in box 2 possion and box 2 on box 1 possion. if the symptoms stay the same the lnb is defective. make sure in the menu of the boxes the lnb power is turned on. if the lnb power is off on one box it will take the other box to activate the other box. keep us informed ralph | ||
My System: i enjoy using computer | thanks for reply there is no spliter in the connection the main lnbf has two lnbs from the company. it's not old "make sure in the menu of the boxes the lnb power is turned on." where is this found??? | ||
| receiver, satellite |
