Thanks, embalse, for your comments and pics. Both will be very useful.
I live in Salamanca, with an 80cm Televés dish and a Mot-Sat 3 motor. A 180cm dish here would give me almost all of Astra 2D, 24/7 (a fellow Brit in town has that set-up and those results). As I explained, that size of dish is not feasible where I live, so the 125cm Gibertini is a compromise. It should also give me stronger reception of Astra 2D, Intelsat 10-02, Nilesat, BADR and a couple of others.
Mostly my problem is getting a qualified installer in town who can set up the system for me. Most installers here are only called upon to install Digital+, hence my inquiry about documentation.
As an aside and as an example of how strange (capricious?) Astra 2D can be, in a village 125k due west of Salamanca, at the Portuguese border, and with the same equipment as in the city, I get all of ITV, Channel 4 (and variants) BBC1 (regional) but not BBC2,BBC3, etc. Depending on how things work out in the city I may repeat the operation in the village.
Thanks again.
[QUOTE=embalse;877838]Hi Jacobo40,
Originally Posted by embalse Hi Jacobo40,
It would help to know where you are in Spain as the size of the dish and type varies widely depending on the location.
As Channel Hopper has pointed out, if you are using a QDF-031/CM Feedhorn, you are best off getting a CM dish.
With regards to connecting the Feedhorn. Here are some pics of my mine... My ChannelMaster 1.2 Madrid. Astra 2D
Make sure the O ring is placed between the QDF-031 and Feedhorn. Only 4 of the screws will align, but thats normal. Make sure it is a tight fit so that no water can enter.
Skew and and Focal Depth will depend on your location.
