Andrews with V box maybe for Triple dragon?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Specialist Contributor Join Date: 16-01-2005 Location: Lancashire
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought. |
I have myself a 1.2 Mtr Andrews dish ![]() I thought this would hook up with my Fortec stab motor but it seems not. The pole width on this Channel Master is a monster, I have never seen a dish with such a wide diameter pole... I have this lovely dish & want to hook it up to my Triple Dragon which uses the coax for it's power not a seperate power cable, I have been told about a v box but I would like some info on how it would work. 1. Would a coax come out of my TD & go to the V box & then a power cable to the dish motor pictured ? 2. Would I still just enter my long/lat & this dish is set up for me or would I have the nightmare of finding the satellites myself? 3. I have a Triax 1 mtr up at the moment would I see a significant boost in signal or would it not be enough to warrant all the messing? I hope someone in the know can advise me on this please? | ||
![]() Last edited by misterminibus; 3 Weeks Ago at 02:00 PM. | |||
| Specialist Contributor Join Date: 01-01-2000
| 1. LNB coax lead - TD to vbox, then vBox to LNB 2. Four cables from vBox to motor - two at 36v for the motor, two for the sensor 3. By definition the vBox is not compatible with ASALS. Each satellite is set manually. 4. You should get an improvement vs the 1m dish, only you can decide if it is worth it. There are many people looking for these Channel Master dishes at a fair price. Sell it if you are not sure. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Not seen a jack fitted that way before to a CM polar mount | ||
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought. | Thanks guys, I want to try it but I don't like the idea of setting all the sats by hand ![]() @Paul "Not seen a jack fitted that way before to a CM polar mount" is that a good or bad thing :lol: | ||
![]() Last edited by misterminibus; 3 Weeks Ago at 09:09 PM. | |||
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | the pole mount is only 3inch so its not a big problem. the dish will be loads better than the triax 1m you have now. when i installed my channel master dish i found it to be straight forward and works much better than a diseqc motor. yes they have bolted the actuator motor the wrong way around, the part where you connect the 4 core cable should be on the right maybe use the dish as a fixed one on a satellite you like to view most ? | ||
| andrews, box, dragon, triple |
